Can you see why I lost oil pressure? lol (PIC) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2011, 09:14 AM   #1 (permalink)
View davj3368's Photo Gallery
4th Generation Can you see why I lost oil pressure? lol (PIC)
Can you see why I lost oil pressure? Wonder how often this happens, and why?
davj3368 is offline   Reply With Quote
Old 05-06-2011, 09:53 AM   #2 (permalink)
View agni's Photo Gallery
I'm not sure I see what you're talking about. Did your oil pump spring a major leak? From what I can see of your crankcase it looks like you've got some sludge issues . . .
agni is offline   Reply With Quote
Old 05-06-2011, 10:07 AM   #3 (permalink)
look closer..... If you're familiar with the Camry engine I think it would be a quick find....
Old 05-06-2011, 10:09 AM   #4 (permalink)
View ruggz's Photo Gallery
The oil pump gear is off center. Looks like the bearing just fell out. Tons of metal shavings in there!
ruggz is offline   Reply With Quote
Old 05-06-2011, 10:15 AM   #5 (permalink)
Yep! Ate a clean 1" hole in the center of the pulley! I quit driving right after I lost oil pressure.... Should have replaced the oil pump when I replaced the water pump a few months back
Old 05-06-2011, 11:24 AM   #6 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
thats nuts. ive never seen that happen before!
Old 05-06-2011, 12:35 PM   #7 (permalink)
Does a new pump even come with that pulley or is it another part? Never mind it does come with it. At $100 bucks it might be a good idea to replace with the timing belt . How many miles do you have on the car.?
Old 05-06-2011, 12:38 PM   #8 (permalink)
The new pump I bought (~$120 from AutoZone) didn't come with a new pulley. It was a seperate OEM purchase from Toyota for ~$30.
The pulley just has a slotted 'D' hole in the middle that slides over the pump shaft. Still wondering how that could have happened...
Old 05-06-2011, 12:42 PM   #9 (permalink)
The one at rock auto comes with the gear or at least they show it in the pic.
http://www.rockauto.com/catalog/moreinfo.php?pk=1810700
Old 05-06-2011, 12:43 PM   #10 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Plenty of life left in that oil pump.
Hopefully the main bearings at least are okay. I'd be worried about metal circulating through the engine, are you going to toss in a new oil pump and see how it runs? Yea the new pumps usually come complete with everything including the drive gear.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is offline   Reply With Quote
Old 05-06-2011, 12:48 PM   #11 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
wow that's sick!
wondering what are chances of that happening .... how many miles on that oil pump? was it a factory OEM pump?
Old 05-06-2011, 12:52 PM   #12 (permalink)
but, it doesn't show a crankshaft seal....which my autozone pump came with.
Old 05-06-2011, 01:22 PM   #13 (permalink)
Oh wow, I definitely see it now. How many miles on the engine, and do you know if the pump was ever rebuilt? Did you notice any noise from the bearing before this happened?
Old 05-06-2011, 01:42 PM   #14 (permalink)
My car has about 160k on it, but this motor was installed last year, and Im not sure how many miles it had on it. Judging from the sludge buildup, I'd say the previous owner wasn't religious with the oil changes.
Looks like the original oil pump. I replaced the water pump a few months ago....wishin' I had replaced the oil pump while I was in there.
Old 05-06-2011, 01:44 PM   #15 (permalink)
抵抗は無駄です
fenixus's Avatar
I see. well that's a mystery motor so all the timing maintenance should have been done all together on it.
if there is no other oil leaks, maybe you run a sea foam treatment through it to clean up the varnish and sludge?
