Will a 98-2001 head fit on a 92-96 5sfe block - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2011, 08:24 PM   #1 (permalink)
View Milkshake's Photo Gallery
I need a new bottom end for my 2001 5sfe, and i have found cheap 92-96 5sfe blocks. I have cross referenced the head gaskets and all 5sfe's from 92-97 use the same head gasket. 1997 was when they went distributorless, just like my 2001 camry. So if the 1997 head is the same as the 2001 then it should in theory fit on a 92-97 block.
1998 block
1995 block
In case the question wasn't clear above, does anyone know if a 1998-01 cylinder head will fit on a 92-96 block? thanks.
Milkshake is offline   Reply With Quote
Old 05-07-2011, 09:47 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
no 1mm difference in the bore, yes lame, but thats what it is
^ and leaving it that way!
Old 05-07-2011, 11:42 PM   #3 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
There was a thread a while back where it was done sucessfully with some work. i believe you need to use the 01 cams on the older head. But it should bolt up and work. I think the crank or cam pos. sensor is a little different on the older engine.
carsrus is offline   Reply With Quote
