Originally Posted by JohnGD
Congratulations!
13,000 miles since the last filter change? That's a loooong life filter.
It probably wasn't tightened properly then. Normally a filter takes 3/4 turn from gasket contact. And after a while you need a wrench to loosen it.
What brand of oil filter and oil?
It was Firestone's filter and Kendall oil that they put in. I know 13,000 sounds like a lot but it was mainly highway driving, which is why I sort of put it off. I changed the oil 2-3 times during that period. But as easy as it was, I can do it every 1,000 miles LOL. I was told that there would be a bunch of oil spilling out in the V6 DIY but that wasn't the case with I4.
I tightened it by hand until I couldn't turn it anymore because I got the wrong size filter wrench. So hopefully it should be tight enough.
BTW, for people who think I'm some boring rookie; I started out with DIY transmission flushes, differential changes, thermostat/Coolant changes and brake fluid changes...without ever knowing how to change the oil and filter LOL. You get so used to shops doing it, you don't think twice...
