98/99 Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2011, 05:33 AM   #1 (permalink)
View CantKillaCam's Photo Gallery
98/99 Spark Plugs
Does anyone know why the 98 Camry(4cyl) specs a standard spark plug and the 99 Camry(4cyl) specs a platinuim plug?
CantKillaCam is offline   Reply With Quote
Old 05-11-2011, 01:51 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
my 98 uses the double grounded platinum plugs... do you have a distributor on your engine? or was the engine ever replaced?
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-11-2011, 02:51 PM   #3 (permalink)
Gameroom cash: $303755
According to the 98 Camry owner's manaul on page 150 it states "Twin ground electrode platinum-tipped spark plugs". On page 226 it gives Spark Plug Type as either:
DENSO 20TR11 or
NGK BKR6EKPB11
Mike
Old 05-11-2011, 07:10 PM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
The twin-ground electrode plug is standard on these waste spark systems (BKR6EKPB-11):
http://ngksparkplugs.com/part_finder...KPB-11%20*%20#
However, NGK Iridium-IX (BKR6EIX-11) works too on these engines according to NGK:
http://ngksparkplugs.com/part_finder...ber=BKR6EIX-11
If you want a cheaper version of platinum plug, the thin center electrode GPower (BKR6EGP) is a good alternative:
http://ngksparkplugs.com/part_finder...number=BKR6EGP
Old 05-12-2011, 05:19 AM   #5 (permalink)
Thanks very much for the quick responses, both have original stock engines, 280k and 190k respectively. The '99 is running smooth but a little tired, I planned on doing a compression check and changing the plugs in the process. Castrol 5w-30w, stock filter, no abnormal oil consumption, air filter clean. The current plugs probably have about 90k on them, ignition wires look original.
Thanks again for the posts.
