Grinding noise, window won't move - - 1995 v6 camry le - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-11-2011, 11:30 AM   #1 (permalink)
View psilence's Photo Gallery
Hello
I have a bit of a problem. My passenger side window is stuck rolled totally down. When I try pressing the switch, the motor makes what I would describe as a grinding noise. It will run (and grind) for about 10-15 seconds, then it sounds as if it runs out of power and just suddenly stops.
This is a big problem, however, because we're getting a lot of rains out here and I need the window to be up.
After searching and reading several threads here, I've decided that it isn't a difficult fix at all and that I will be buying the complete regulator kit on ebay or at advance auto when I go there later on today.
DIY Replace Window Regulator - Camry 92-96 & Equivalent Models
Window motor?
Window Regulator
Power Window Motor
My question is, what can I do to roll the window up in the meantime, seeing as it will probably be a few days before I can get to replacing the regulator?
Do I need to completely take the panel apart in order to force the window up? In which case, I might as well just replace it while I'm in there.
Thanks, I appreciate any help.
psilence is offline   Reply With Quote
Old 05-11-2011, 02:10 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
If you take off the inner panel, that'll give you access to the two nuts holding the window to the regulator. Remove them and that'll allow you to lift the window and tape it up in the closed position. Then just leave the inner panel off until you get the new regulator.
That's what I'd do.
BMR is offline   Reply With Quote
Old 05-11-2011, 03:56 PM   #3 (permalink)
Gameroom cash: $254267
View sarsman45's Photo Gallery
Or you can manually turn the actuator to push it up. It sounds as if your teeth for the regulator is gone or the teeth on the line that controls it is gone.
Do what BMR told you to do. Just an FYI be careful pulling stuff apart. Hidden screws galore and be careful taking the control panel for that door off. It will run a pretty penny if you accidentally break something on it. The window components are behind a water guard on the door sealing water out so make sure you dont destroy that too.
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 05-11-2011, 09:21 PM   #4 (permalink)
Morg's Avatar
View Morg's Photo Gallery
That's what I'd do.
Safe bet, Exactly what I had to do on mine. Since I'm reasonably certain for me its both motor and regulator and/or a bad connection somewhere in the DS door. At one point I couldn't get it to close and ended up getting frustrated and just found a good DIY video on how to remove my door panel. Its really touchy to do but definitely beats paying someone to take the door apart.
Morg is offline   Reply With Quote
Old 05-12-2011, 09:04 PM   #5 (permalink)
Thanks for the advice guys. I wound up taking the door panel off, disconnecting the window from the regulator, and just taping it up to the top of the door. From start to finish, took about 20 minutes, though I did manage to crack the trim around the door handle.
After I got the panel off, I discovered what had happened. The wires had gotten caught in the capstan, gotten it stuck, and caused the entire regulator to fail. I'll have to buy a whole new kit now.
It appears the only complete kits on ebay run about $70. I was seeing $35 quoted in some of the other threads I linked. Is that just what they're going for now?
Old 05-12-2011, 09:27 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
I see them for about $30 without the motor, like this one, and this one.
...and $40 with the motor, like this one, and this one.
Old 05-14-2011, 07:56 PM   #7 (permalink)
View 96v6wagon's Photo Gallery
Grinding noise, window won't move - 1995 v6 camry l3
I ordered one online from 1aauto.com in Dec. - can't remember how I found them - might have been via amazon. Anyway it was for a 1996 camry driver side front. it was $63, free shipping. As I recall I saw something in a review at their site about the motor being quiet. And although it was more $$ I decided to go with them for that reason - last thing I wanted was to get the job done then have a noise issue with the new motor. So, for what that's worth.
BTW this past year has been nothing but door issues - I've heard when Camrys get this age, that starts happening. I've had to replace 3 interior latches, various bezels, the driver's door window regulator, the exterior latch on the driver's door (it just broke off in my hand one morning, and I'm a tiny gal), and one month after that, the door lock cylinder on the driver's door. I think the front passenger window regulator is going to be next. gad!
96v6wagon is offline   Reply With Quote
Old 05-14-2011, 08:03 PM   #8 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Yeah you have to be easy on these older cars. When I was younger I broke the passenger door handle on my Dad's 88 Acura Legend and it was metal lol. I was like 12 years old.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
