How's the condition of the dog bone (torque strut) rubber? How's the engine movement when shifting into D/R? This will help determine if you need to change the mounts if you plan to keep the car just one more year or slightly longer.
That said, if they pull the engine then it's a good time to change the rear engine mount too. It's much harder to get to otherwise. But since one failing mount can damage others, I'd just do the two main ones (front hydraulic mount and rear engine mount), the "dog bone" torque strut on the passenger side strut tower, and the transmission mount on the driver side subframe.
Reseal the oil pan. Fel-Pro cork-rubber gasket or Permatex Ultra Black or Ultra Copper RTV. There is always the Toyota OEM FIPG too. Check the valve cover gasket.
Since the input end of the transmission is accessible, consider the ATF pump seal (behind the torque converter). This seal can leak if the torque converter is left on the transmission for a while. For about $3 (online) I'd just change it while in there.
I'm not sure you want to work on the timing components at this time. But these aren't difficult to get to once the engine is installed back in the car. However this is getting involved.
The oil pump housing to block joint should be check for leaks.
Originally Posted by ldballoon4
Im about to have my rear seal replaced in my 1995 Camry(285k!), by a reputable shop. She runs solid and only has this problem. I would like to get another year of use, or more, if possible after this repair- $680.00 vs the dealers $1250.
I have a few questions:
Should I replace the motor mounts too? How many are there?
Besides the main seal, are there any other seals I should replace while the engine is out?
Another things I'm missing?
Tips suggestions?
Thanks
