Now a question about power steering fluid... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2011, 05:11 PM   #1 (permalink)
Mario Mobile
DM616's Avatar
Gameroom cash: $221100
View DM616's Photo Gallery
Since I'm flushing coolant real soon, what do I do about power steering?
I have a few questions:
I know it's ATF instead of actual PSF for Gen4 Camrys...it should be red right? Cause mines a bright amber it seems.
How high should the level be in the reservoir tank? There only seem to be markings for hot/cold..
Should I flush it? I'm sure the original owner didn't even do anything to it. It's got 81300 miles.
If I do flush it, how? I watched videos, and even read the DIY, but I don't understand what you disconnect to a bucket and what you hook up to the tank.
I know that you try to pump out all the excess fluid in the tank with a shampoo bottle pumper. Then you disconnect some hose into a bucket, and then do something to stabalize pressure so when you turn the wheel fluid comes out...or I don't know lol.
Any help appreciated.
DM616 is offline   Reply With Quote
Old 05-12-2011, 07:05 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Some say the Toyota PSF is Dexron without the red dye, but from the smell and consistency it's more like regular PSF. But that's just my opinion. If you can get Mobil-1 fully synthetic ATF (Dexron II/III type) from a local Advanced Auto with a coupon discount of about $5/qt, then go for it.
If not Mobil-1 I'd use Castrol Import Multi-vehicles ATF or Walmart's SuperTech Mercon-V (both are D-II/III type fluids). But I wouldn't use a thin fluid like Dexron VI (6) or plain dino Dexron.
This engine-off flush method is excellent.
http://www.toyotanation.com/forum/t19334.html
You don't really need a shampoo pump. Just disconnect the return hose, plug up the reservoir so ATF doesn't leak from there obviously. Then use a 3/8" coupler to a 3/8" ID PVC hose to a waste bucket. The old fluid in the reservoir will get flushed out anyway. (that said I'd siphon out brake fluid full of moisture out of the master cylinder reservoir before flushing however).
When you turn the steering wheel, the piston inside the steering rack will move in one direction. This action squeezes out the ATF in that side of the chamber. Then as you turn the steering wheel the other way, the old ATF gets squeezed out the other chamber while the empty chamber draws in new ATF from the reservoir.
Therefore repeat this process a few times while you fill the reservoir with new ATF. Run about 2 qts through it. And every year just siphon out the ATF in the reservoir and refill with new fluid is all you need to do after that.
Old 05-12-2011, 07:08 PM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I looked at the 99's service records and at 40k all fluids were flushed. Interestingly the dealer used Mercon for the Power Steering and Transmission.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-12-2011, 07:08 PM   #4 (permalink)
Mario Mobile
DM616's Avatar
Oh okay makes a little bit more sense now.
So should I flush it? Or can I just take the shampoo head, remove excess liquid, put in new, turn wheel, remove old, put more in, and repeat this a few more times?
And do I need to lift up the car?
Old 05-12-2011, 07:10 PM   #5 (permalink)
Avy
I would suck out all the fluid from the reservoir and refill, like you said. I did it once today on our Quest and the steering wheel turns so easily now.
And no you don't need to lift the car, I put newspaper around the reservoir to catch any spills.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-12-2011, 07:12 PM   #6 (permalink)
Mario Mobile
DM616's Avatar
Alright, so if I pump it out, then refill, then turn, how many times should I repeat this? 3?
Time to go buy some dexron 3
Old 05-12-2011, 07:24 PM   #7 (permalink)
Avy
I don't turn the wheel unless air gets in the system. My guess, turn to lock to lock, so once in both directions.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-12-2011, 07:27 PM   #8 (permalink)
The new formulation Mercon-V replaces the old "Mercon" (Dexron/Mercon), which is discontinued. M-V is more shear stable and Ford tightened it's spec so any Mercon-V you get will be fairly consistent. That's why I'd recommend Walmart's SuperTech Mercon-V. It's just a better fluid than plain dino Dexron, but clearly Mobil-1 fully syn will be better.
Old 05-12-2011, 07:34 PM   #9 (permalink)
I'd do 3 times in each direction since you have everything apart. And in the future just siphon and refill every year.
I'd use Walmart's SuperTech Mercon-V or Castrol Import Multivehicle ATF from Walmart over dino Dexron III types.
Old 05-12-2011, 07:34 PM   #10 (permalink)
Avy
Aha, using M-V next service then. Also, explains why I was confused when the fluids weren't clearish when I first changed them. What was weird is when I changed the PSF on the quest it was Red tinted, and I checked the FSM indeed its PSF not ATF.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-12-2011, 07:38 PM   #11 (permalink)
Yes, it's a difference you can feel!
Old 05-12-2011, 07:42 PM   #12 (permalink)
Mario Mobile
DM616's Avatar
Can anyone else confirm Walmart's SuperTech Mercon-V is applicable? It's just I don't want to destroy my steering rack haha. I'll be picking this up if it's okay that it MAY mix with whatever was previous in my tank.
And nobody answered...where is the marking for the reservoir? No idea on how much to put in.
Old 05-12-2011, 07:43 PM   #13 (permalink)
The problem is some mechanics just use whatever they feel like. But we know better and will follow the specification. Some early Toyotas used PSF instead of Dexron.
Old 05-12-2011, 07:47 PM   #14 (permalink)
Avy
Yes it is.
When the engine is cold use the "COLD" marking, once its hot use the "HOT" markings. So basically just fill up to FULL on the COLD marking, drive around until warm, then top off until the FULL marking on the HOT level.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-12-2011, 07:48 PM   #15 (permalink)
Mario Mobile
DM616's Avatar
Haha yah, I'm beginning to hate mechanics. Though there is this one russian mechanic by my house...he's real nice when he did my inspection.
Alright, just wondering how much to fill it up to. If no one knows I'll fill it until the hot line or whatever was highest.
