Possible to retrofit a cabin air filter ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2011, 09:45 PM   #1 (permalink)
Gameroom cash: $148300
View SilverSoarer's Photo Gallery
Since Gen 3 does not have cabin air filters - has anyone been able to filter incoming air for pollen ?
SilverSoarer is offline   Reply With Quote
Old 05-17-2011, 10:45 AM   #2 (permalink)
bump
Old 05-17-2011, 08:34 PM   #3 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If you have access to Toyota's online catalog then compare the Gen 4 Avalon's HVAC unit with your Gen 3 Camry's. At least rockauto shows the heater core and evaporator are the same in Gen3 Camry and Gen4 Avalon, so my guess is they share *some* similarities.
If the evaporator/heater housing are identical that's a good sign. Because it's the blower fan housing that needs to be bolted to the evap/heater housing. The only problem can be the intake into the blower housing is located at a different location on the Gen4 Avalon than the Gen3 Camry.
For some reason Toyota decided to remove all catalog pictures from dealer websites. Must be a part of the dealer economic stimulus package.
Old 05-18-2011, 07:02 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
Epic
u sure about that.....
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 05-19-2011, 09:51 AM   #5 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
im sorry but i have to steal this thread.
i wanted to replace my gen4 cabin air filter but when i called the dealer parts, they said my car doesn't have that part.
my car smells like azz (mildew ?) so i thought it might've been the cabin air filter so i was gonna replace that, and clea my carpet. but since they said that theres no cabin air filter, then i guess my only option is to clean the carpets.
so it is true that theres no air filter in the gen4 either ? or...
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 05-19-2011, 09:55 AM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
no air cabin filters in gen4.
all you can do is to spray Lysol anti-bacterial spray (around half a can) into cabin intakes under windshield on running car (and a/c+fan at full blast) and let it do the job.
keep the windows rolled down when you do this, or you will get a nasty cough upon re-entering the car
Old 05-19-2011, 10:15 AM   #7 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
I think it may be possible. When I replaced the filter in the 07 the duct that comes from the windsheild to the top of the blower motor I believe was separate from the motor. You could probably swap one from a newer Toyota or do some modification. I would have to look at it again to see if it's separate.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-19-2011, 04:08 PM   #8 (permalink)
I HAS BOOST!!!
bigbird's Avatar
why gehtto rig something when a factory option exists for the car? it doesnt even require a different rear deck, just holes cut and mounting hardware.
R.I.P.
Car Domain:
Old 05-19-2011, 04:46 PM   #9 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
What is the Pros of running a Cabin Air Filter?
Old 05-19-2011, 04:46 PM   #10 (permalink)
Old 05-20-2011, 11:25 PM   #11 (permalink)
to filter out bad stuff i guess. kinda like how houses usually have air filters for the central air.
wher is this air intake ?
^^^ List of my mods
Old 05-20-2011, 11:42 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
open the hood and look right below the windshield and wiper arms. you will see a mesh of tiny holes in plastic, there is 3 points of air entry, left side, center and right side.
on the inside of car there is some sort of a duct interconnecting them and routing to cabin blower motor (behind glove box).
last time I just sprayed like half of big Lysol anti-bacterial spray through those openings, on running car (a/c at full fan blast at various settings) and it removed the smell of mold.
you will probably smell some lysol for next 2 days after you do this though
Old 05-21-2011, 02:04 AM   #13 (permalink)
hehe and clean out the lungs quite well too.
