This past Monday I started to change the upper idler on my 3VZ. I was going to try and fit a subaru one (i work at a subi dealership) to try and save money. Well it was just a hair smaller and the bolt size was smaller as well so it wouldn't work. I then just ordered an oem one. Well I was trying to just slide the belt on over the pulley without taking off the belt and it jumped :/
Now i have to take apart the whole timing assembly, I have everything off except the crank pulley. The specs for it say to torque the bolt to 181 ft/lbs. I tried using a small impact gun that maxes out at 90 ft/lbs and that didn't work. So then I went to work and got my MG725 which is the biggest one they make. It puts out 810 ft/lbs and the bolt still wont even budge!!
So do you guys have any ideas on what I should do?
Use the starter bump method. I put a breaker bar against the control arm, lowered the car until the bar was tight between the arm and floor then blipped the starter a few times and it was loose.
If all else fails, use Oxygen / Acetylene torches and heat up the Crankshaft area (around the bolt)... let it cool completely, then try it. If it doesnt work Repeat the process. It will come off
yup, 5s-fe crank bolt torque per FSM is 80ft-lbs, of course it will be much more to remove that thing if it was never touched. however later when re-installing it 80ft-lbs is all it needs.
You need 6 CFM @ 90 PSI for 8 seconds to get that crankshaft bolt off - most compressors sold for the average DIYer cannot provide that output.
I had my Ingersol Rand impact set at around 100 PSI with a Porter Cable pancake compressor putting out around 2.5 CFM and mine came off like a piece of cake when I did my timing belt job a few months ago... Maybe it wasn't on as tight, I don't know. I definitely need a bigger compressor though......
