1993 Cmary Engine Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2011, 04:43 PM   #1 (permalink)
View jc_mk2's Photo Gallery
I have a 1993 camry with the 3vz v6. I have a good deal on a 1mzfe engine out of a 1995. Was wondering if anyone new the troubles of interchanging these two?
I need a new engine =/
jc_mk2 is offline   Reply With Quote
Old 05-14-2011, 04:51 PM   #2 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Just curious, but is there any particular reason you don't want to just buy the '95 as a whole car? Is the body on that car in bad shape of something?
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 05-14-2011, 05:03 PM   #3 (permalink)
The 95 is totaled. Guy lives not too far from my house, and said if i take it out he'll give it to me for $150. The only thing wrong is that the motor mount pushed the water inlet and cracked it but thats an easy replacement. Car had only 103K original miles.
Old 05-14-2011, 05:34 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
The 3VZ engine is completely different than a 1MZ.
OBD I Vs ODB II
Ignition system has distributor/one coil/HT wires Vs igniter/coil-over-plug
Different O2 sensors
Just to name a few things that pop to mind. It would be such an enormous task, I wouldn't recommend doing it unless you've got a lot of time on your hands to learn all the pitfalls & work-arounds. You'll need to swap ECUs, wire harnesses, etc., etc..
BMR is offline   Reply With Quote
Old 05-14-2011, 05:54 PM   #5 (permalink)
OBD I Vs ODB II
If i purchase this engine, id be getting everything. The guy said i can have the motor complete with harness, fuse box, ecu, etc. id basically taking it out whole with out disconnecting the harness so ignition system and all wouldnt be a problem. Im sure i can buy the o2 off of him too. Would it still be a problem? Or fairly simple?
Old 05-15-2011, 06:07 AM   #6 (permalink)
Pvt-Public's Avatar
Gameroom cash: $274350
View Pvt-Public's Photo Gallery
If your state has an emissions inspection program you may fail automatically since that engine was not the size/type that was EPA certified in that car.
Pvt-Public is offline   Reply With Quote
