We have 1997 Camry v4 2.2L, every time I use the car in traffic, the A/C light blinks and then the blower will start blowing hot air, to temporarily resolve this issue I turn off the A/C then turn it on again and the blower will start blowing cold air.
My mechanic said that I need to replace the board that controls the A/C,
Any idea how will I validate my mechanics suggestion? and what do you call that board that controls the A/C.
The light flashes when the RPM of the compressor differs from the RPM of the engine. This can happen, as you said, if the compressor is seizing, the AC belt is slipping, or the clutch isn't engaging.
Check the AC charge first.
In the US we have these Walmart cans that we can add a few oz after about 4-5 years to make it cold again. There was an EPA study that the average leak rate is 10% per year. I think that's high for later model years however.
Originally Posted by abigor
Hi ALL!
Thank you John, what do you mean by A/C charge?is that a freon in can? if you are talking about the freon then I don't think it's the freon as my mechanic refilled it before I opened this thread.
Anyway what's the standard alternator for 1997 camry? (70A, 90A or 110A)
It should be a 90A alternator.
Thank you for your time and idea.
A/C charged is the refrigerate in the system. (Freon is DuPont’s brand) If the system is full at the correct pressure; I would check to see if the compress is engaging. With the engine running, you can check to see if the compressor clutch is engaging or slipping. You should see and hear it click in and out and cycle over when load is light.
Also, what is your idle speed in gear? 650-750rpm is normal.
I learned something new today (Freon is a brand)! Thanks!
For your question, I think my idle at drive gear is around 800-850rpm.
It's very hard for me to observe the slipping as it only happens when I'm caught up in traffic but I will still try.
