2000 Camry Transmission Vibrates in Forward Gears only?
Car was running fine, then all of a sudden, the transmission started acting up. This is what I've noticed....
Car seems to be idling a few hundred rmp's higher than usual. Normal is about 800....now it's around 1100 or more.
When I put car in reverse, it works normally, smooth backing....but when I put car in any of the Forward gears it starts shaking and vibrating.
Gonna drain the fluid and look at the filter while I wait on some of your responses.
