95 4 cyl spongy brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2011, 09:05 AM   #1 (permalink)
View markdunn99's Photo Gallery
95 LE 4 cyl....brake pedal is very soft...travels all the way down....brake operation is fine....front pads are good and fairly new...rear shoes are worn but problem has been around for quite a while even with newer rear shoes....have bled it several times with no difference....what else can make the pedal spongy like that? Thanks
markdunn99 is offline   Reply With Quote
Old 05-15-2011, 09:19 AM   #2 (permalink)
Specialmen240's Avatar
View Specialmen240's Photo Gallery
the problem in the brake master cylinder mybe its need for repaire kit
Specialmen240 is offline   Reply With Quote
Old 05-15-2011, 09:28 AM   #3 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
If it's not air I would suspect the master cylinder as Specialmen240 suggests. Put the car in drive and apply the brake strongly and hold it, does the pedal slowly descend to the floor? Being a 95 I'd also inspect the brake hoses at the calipers for cracks and bulging when brake applied.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 05-15-2011, 10:28 AM   #4 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
If you rapidly pump the brake pedal does it rise/firm up? If so it's most likely air in the system. If it doesn't then MC cups are probably leaking. But you still have to check the rubber brake hoses for swelling.
Do you have ABS?
Old 05-19-2011, 07:38 PM   #5 (permalink)
Gameroom cash: $120900
View rizzy's Photo Gallery
3rd Generation
Do you have ABS?
hate to hijack the thrend, but my car is ABS and i have a similar problem. its spongy but hold well, and the ABS light come and and go off every so often, the peddle just have to be press almost half, i change ma MC and same thing someone told me it can be the paportionary valve thats on the firewall with have all the lines to it. car is a 94 LE 4cly ABS and have disc all around.. any advise is well appricated
rizzy is offline   Reply With Quote
Old 05-19-2011, 09:00 PM   #6 (permalink)
Samething. Try rapidly pumping the pedal and see if it rises up. If so it's most likely air in the system.
ABS is hard to bleed. There is the ghetto method of activating it on gravel road and bleeding again. May not be that reliable. Or take it to the dealer to tickle the abs module.
