Re ACIS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2011, 05:02 PM   #1 (permalink)
View Dayak's Photo Gallery
Re ACIS
My car is toyota camry 1993 V6 LE 3VZ-FE engine. How do I test the ACIS? Does it need for the car to be running or under loaded conditions? Or can it be tested at standstill(no load) by running the engine at more than 3,900 rpm and throttle at 60 deg or more? Also, if the ACIS is permanently activated(closed valve), will it give NO(nitrous oxide i guess) gas emissions and fail the NO emission test? Thanks...
Dayak is offline   Reply With Quote
Old 05-16-2011, 09:15 PM   #2 (permalink)
Bdub215's Avatar
Gameroom cash: $316065
View Bdub215's Photo Gallery
if you really wanna test your ACIS, take off your stock air box leaving the AFM, and air tube connected. around 3850 rpms you should hear a very audible Vtecish change in the engine sound.
ACIS is engaged twice in my video here.
and whether or not the ACIS is working, from the time there is a load on the motor noX (oxides of nitrogen not nitrous oxide) is being produced. if you fail the emissions test depends on how well your car is running.
93 Lexus ES300 5spd I/E URSB
Bdub215 is offline   Reply With Quote
Old 05-17-2011, 04:53 PM   #3 (permalink)
Thanks for your video. My concern is I want to see the ACIS activated by the ECM(engine control module) when I increase the engine to 3900 rpm without running the car in motion. Is this possible?
Old 05-17-2011, 06:36 PM   #4 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426953
View EEngineer's Photo Gallery
look at the little arm thingy from the actuator that activates the ACIS at the side of the plenum
see if it moves when u rev the car at idle. if it doesn't then i guess u'll have to listen for it when u drive
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is offline   Reply With Quote
Old 05-17-2011, 08:16 PM   #5 (permalink)
Bdub215's Avatar
^ this. doesnt move when you rev like on the 2JZ.
Old 05-18-2011, 04:27 PM   #6 (permalink)
The input to ECM in order for the ACIS to be activated is only engine rpm(>= 3900rpm) and throttle opening(>60 degrees). That means ACIS can be tested without the car running?
Old 05-18-2011, 06:40 PM   #7 (permalink)
Freakin Scooters
LynchburgCSI's Avatar
Gameroom cash: $1409695
iTrader Score: 16 reviews
Snugly put a zip tie on the actuator arm up against a surface. Go for a drive. If it moves from the original position, it works.
'07 Honda Ruckus Big Bore
