Hid problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2011, 06:20 AM   #1 (permalink)
akcc's Avatar
View akcc's Photo Gallery
Hid problem
Hi, I have a hid problem, I have h4-3 installed on my camry 1999 with a relay harness and I bought my hids from ddm. Basically the problem is, my hids won't turn on when the car is on, even if I switch night time lights on. But if I switch the night time switch on before I start the car, it would work. I have tried changing the ballast, and so far it's been 3 sets of ddm ballast that does the same thing... The same thing happens to my girl friend's corolla 2001. What could be the problem?
Toyota Venza 2010 AWD v6
OEM HID + 6000k D4S Bulbs
XM Platinum Series H11 8000k Digital HID
Toyota Camry 1999 XLE v6
XM Platinum Series Bixenon 6000K 55w Digital HID
akcc is offline   Reply With Quote
Old 05-17-2011, 08:02 AM   #2 (permalink)
dorifuto.boi's Avatar
Gameroom cash: $171700
View dorifuto.boi's Photo Gallery
im pretty sure u hooked it up wrong. mine worked just fine when i had it that one week.
if your sure that u hooked it up right then it might be the relay. unplug the ballasts and check that the ballast is seeing voltage with a voltmeter when you turn then lights on with engine off and with engine on.
if u replace the relay and the ballast is still not seein 12v everytime u turn on ur lights then somethin is wrong w ur car
http://web.ics.purdue.edu/~dfung/car.html
^^^ List of my mods
dorifuto.boi is offline   Reply With Quote
Old 05-17-2011, 08:02 AM   #3 (permalink)
dont use hid kits =]
^^^ List of my mods
Old 05-17-2011, 10:46 PM   #4 (permalink)
akcc's Avatar
Well before was working fine when I first installed them, I was originally on analog ballast but ever since I switched to digital, this started happening and I will try with the volt meter
