You should definitely do a flush, or if you're lazy or don't have the right tools/hoses to do a flush, then use a turkey baster. Use the baster to suck out as much fluid as you can, then top it off, run the engine for 30 seconds. Do this several times and you will have swapped out most of the old fluid.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
