235/45R17s on gen 4. Will they fit? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2011, 02:27 AM   #1 (permalink)
View Kevs Toy's Photo Gallery
As the title states, I'm wanting to run 235/45R17s on my gen 4. A friend just offered me a used set of re-11s at a great price and id like to pick them up. I know this would be a suitable size to run as it's only off the stock circumference by 1 %. However, I'm concerned about rubbing, moreso on the struts. My car is currently lowered with Eibach springs on Tokico struts. I was planning to run a 17X7.5 wheel and most likely it would be in a 45 mm offset. Would this be sufficient clearance or do I need a lower offset wheel? Would spacers possibly be enough if the offset just needs to be slightly lower. Seems to be hard to find lightweight 17 inch wheels in a lower offset
Kevs Toy is offline   Reply With Quote
Old 05-22-2011, 06:36 AM   #2 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
There's really no way of telling unless another person has done the EXACT specs of tire and wheel on their car. and then even that, there's different wheel designs that are slightly different from one another. you pretty much got it, stick em on and if they rub add some spacers. you might need to roll your fenders with the oversized tires though.
iovaykind is offline   Reply With Quote
Old 05-22-2011, 07:44 AM   #3 (permalink)
Gameroom cash: $323580
View Cartang's Photo Gallery
I have this set up for 11 years , 235/45/17 in Enkei Shogun rims , needs to shave rear fenders. my car is lowered with trd springs.
I hope it help
Camry 99,SC 6psi,5sp,CPE intake,OBX headers, Jim's fuel system,Walbro pump, NST pulley,Greddy exhaust,Whiteline sways bars ,TRD strut bar,TRD shifter,Exedy clutch,Fidanza flywheel.
Camry2007 ,V6,SE,TRDcat back system, Fujita CAI,TRD springs ,UR(R) sway bar 23 mm,UR(F) 4 points,Lexus GS 430 rims.
Cartang is offline   Reply With Quote
Old 05-22-2011, 11:49 AM   #4 (permalink)
Thanks for the response, Cartang. Is shaving the fenders like rolling them at all? Running any spacers?
Old 05-22-2011, 03:12 PM   #5 (permalink)
Yes rolling the fenders , I dont use spacers, It was made in a body shop
Old 05-22-2011, 04:33 PM   #6 (permalink)
93 Camry LE 5S-FE
4Cyl'erThriller's Avatar
Gameroom cash: $428696
iTrader Score: 15 reviews
View 4Cyl'erThriller's Photo Gallery
I ran 235 45 17s on an 8" rim and it rubbed the fenders ever so slightly. Not enough to even leave marks on the tires but enough that I knew it was happening. I was lowered on tokicos and eibachs too. I dont remember the offset of my rims off the top of my head tho. its probably around 40ish +/- You shouldnt have much of a problem
4Cyl'erThriller is offline   Reply With Quote
Old 05-22-2011, 06:32 PM   #7 (permalink)
Thanks for the feedback guys. I found enkei rpf1s in 35 mm offset so hopefully won't need the spacers but prob. will have to do the fender rolling.
