Broken key stuck inside trunk lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2011, 11:38 AM   #1 (permalink)
View musicgold's Photo Gallery
Hi,
My key broke inside the truck lock. I am able to use another key to open the truck by partially inserting the key into the lock and turning it. In fact I can use any key, insert it into the lock partially and open the lock.
Any ideas / suggestions?
Thanks.
musicgold is offline   Reply With Quote
Old 05-22-2011, 05:42 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
my suggestion that would be the easiest would be to go to the salvage yard, get a car that has a key in it. Make sure the trunk lock works. Then remove the lock and take the key. Use a separate key when using the trunk.
Thats the easy way.
Now if you are a bit more daring, I would suggest to remove the locking cylinder and take it apart. Push something through the back side of it to dislodge the broken fragment of key.
Or, you could call a lock smith and have them do what I listed second and pay them like $100-$300.00 to do that.
So rundown ..
Option 1 = $5-15.00
Option 2 = FREE
Option 3 = $100-$300.00
good luck
Old 05-22-2011, 07:20 PM   #3 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Could a strong magnet get it out?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-23-2011, 01:49 AM   #4 (permalink)
View sssgood's Photo Gallery
tweezers?
sssgood is offline   Reply With Quote
Old 05-23-2011, 01:33 PM   #5 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
I'm pretty sure they're made of brass, so a magnet won't work.
If it were me, I'd try Mr. P's option #2.
BMR is offline   Reply With Quote
Old 05-23-2011, 03:07 PM   #6 (permalink)
View corolapete's Photo Gallery
I would take cylinder out and take to a locksmith. $10 tops
corolapete is offline   Reply With Quote
Old 05-24-2011, 08:46 AM   #7 (permalink)
corolapete . You from Irvine, Pa ?
I'm not sure what lock smith you go to but if they only charge $10.00 to remove a key then I want to know his name and number. lol
I had a lock smith unlock my car, it took them literally 10 seconds and it cost me $75.00
