cold start rev - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-22-2011, 12:16 PM   #1 (permalink)
akcc's Avatar
View akcc's Photo Gallery
Canada cold start rev
during cold starts, my camry xle v6 1999 revs at 1.8k-2k rev on cold starts, is that normal? my brother's camry le 4 cyl 1999 revs at 1.2k-1.3k and drops down to 1 after 1 minute where as mine drops after 3 minutes, is that normal for my camry to do something like this?
Toyota Venza 2010 AWD v6
OEM HID + 6000k D4S Bulbs
XM Platinum Series H11 8000k Digital HID
Toyota Camry 1999 XLE v6
XM Platinum Series Bixenon 6000K 55w Digital HID
akcc is offline   Reply With Quote
Old 05-22-2011, 03:45 PM   #2 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
1mz-fe are known to rev higher at cold starts. my '02 1mz does exact same thing, even at 60F at cold start the initial revs shoot up to 1,600-1,800rpm while 5s-fe at same temperatures does only 1,200rpm tops under same conditions.
both cars have new ECT for EFI sensors and proper idle speed once warmed up (no IAC valve problems).
it's normal.
Old 05-22-2011, 04:01 PM   #3 (permalink)
akcc's Avatar
alright, thanks, i wasn't sure because i saw many other camry's and they didn't rev as high as my car during cold starts so i got a bit worried.
Old 05-22-2011, 04:05 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
well, usually you see cars (1mz) being re-started after some driving (warm start), and it no longer does that then.
it's happening only when you start it dead cold, cold start being defined as starting the car after it's been sitting for at least 8 hours.
There must be some threshold coolant temperature after passing which ECU no longer commands it to rev as high (on start) as it would when car was dead cold.
Old 05-22-2011, 04:10 PM   #5 (permalink)
akcc's Avatar
actually, it was same camry same conditions, because my friends own camrys from 1998 to 2001 and they all have different revs with similar mileage as me and it was left to sit after a day, this wasn't just once or twice, its all time. but regardless of that, i am glad to hear that it is normal.
Old 05-22-2011, 04:26 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
likely he's got a different ECU with different programming. even same year/model of car have multiple sub-models (emissions, immobilizer, trim dependent, transmission, engine, etc.) and different ECU can behave differently.
even updated software (e.g. from later year which still matches) on ECU for same exact model/year/specs can be totally different. have seen that with wife's car ECU (factory vs replacement from later year).
Old 05-22-2011, 04:36 PM   #7 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Look into doing this.
http://www.automotiveforums.com/vbul....php?t=1014511
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-22-2011, 04:48 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
higher engine revs at cold start are there for a reason. sticking a fake resistance reading into that circuit to lower the initial RPM will only make the warm up process longer (running RICHer until warmed up).
I wouldn't dare messing with ECT feed for ECU, it's one of primary inputs, it can screw up engine real bad if things go wrong ...
Old 05-22-2011, 04:55 PM   #9 (permalink)
Avy
Wouldn't the ECU send less fuel?
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-22-2011, 05:03 PM   #10 (permalink)
抵抗は無駄です
fenixus's Avatar
yeah, actually it could send less fuel than needed during warm up phase. however this is not based only on ECT for EFI readings. ECU relies also on AFR/oxygen sensors readings, so it's hard to say what it would do.
anyways, cheating on coolant temperature during warm up can't be good in a long run.
I don't care about higher engine revs when car is cold. it's there to help it warm up faster and become more efficient faster than with a "mod" (it's a poor idea to mod that thing).
with this mod on the car will be warming up god knows for how long and what's worse ECU will think the car IS already warmed up, so it will switch to commands for a fully warmed up car (different patterns and fuel maps and trans shift points than when cold).
IMHO, that mod is asking for trouble.
Old 05-22-2011, 05:31 PM   #11 (permalink)
Avy
I will like the shifts points to be normal, that is so annoying. I know my friend's ES300 has regular shifts points at cold temperature so it shouldn't harm anything.
So in summary, the ecu will think the engine is warmer than it actually is. All settings will adjust to what they would be at temperature. I never let the car warm up, just get in, choose a song on my iPod, turn on A/C if needed and GO. I might try this after asking the user if any negative effects has happened since then.
99 Avalon XLS-149k
99 Lexus LS400-88k
Old 05-22-2011, 05:46 PM   #12 (permalink)
抵抗は無駄です
fenixus's Avatar
choice is yours. only thing that ECU will think car IS ALREADY warmed up (around 250ohm on ECT sensor on average) while it will be still stone cold (normally up to 5-12K ohm on ECT sensor depending on climate/weather conditions) ...
Old 05-22-2011, 07:39 PM   #13 (permalink)
Avy
Is that a bad thing? Texas is always hot.
Mobil 1 Super Full Synthetic is on sale @ O'Reilly. $3.49/qt until the 24th. I just got 7 quarts for the 07.
99 Avalon XLS-149k
99 Lexus LS400-88k
