HINT:
Using SST 09843 −18020, connect the terminals Tc and E1, and remove the short pin.
If a malfunction code is displayed during the DTC check, check the circuit listed for the code. For details
of each code, turn to the page referred to under the ”See page” for respective ”DTC No.” in the DTC
chart.
DTC No.
(See Page)
Detection Item Trouble Area
11
(DI−480)
Open circuit in ABS solenoid relay circuit
ABS solenoid relay
12 ABS solenoid relay circuit
(DI−480)
Short circuit in ABS solenoid relay circuit
13
(DI−484)
Open circuit in ABS motor relay circuit
ABS motor relay
14 ABS motor relay circuit
(DI−484)
Short circuit in ABS motor relay circuit
21
(DI−487)
Open or short circuit in 2−position solenoid circuit for right front
wheel
ABS actuator
SFRR or SFRH circuit
22
(DI−487)
Open or short circuit in 2−position solenoid circuit for left front
wheel
ABS actuator
SFLR or SFLH circuit
23
(DI−487)
Open or short circuit in 2−position solenoid circuit for right rear
wheel
ABS actuator
SRRR or SRRH circuit
24
(DI−487)
Open or short circuit in 2−position solenoid circuit for left rear
wheel
ABS actuator
SRLR or SRLH circuit
31
(DI−489)
Right front wheel speed sensor signal malfunction
Right front, left front, right rear and left rear speed sensor
Each speed sensor circuit
Speed sensor rotor
32
(DI−489)
Left front wheel speed sensor signal malfunction
33
(DI−489)
Right rear wheel speed sensor signal malfunction
34
(DI−489)
Left rear wheel speed sensor signal malfunction
33, 34
(DI−495)
Rear speed sensor rotor faulty
Rear axle hub
Right rear, left rear speed sensor
Rear speed sensor circuit
41
(DI−496)
Power source voltage down
Battery
IC regulator
Power source circuit
49
(DI−499)
Open circuit in stop light switch circuit
Stop light switch
Stop light switch circuit
51
(DI−501)
Pump motor is locked ABS pump motor
Always ON
(DI−502)
Malfunction in ECU
ECU
BOTTOM LINE, YOU MUST REMOVE THE SHORT PIN FOR CHECKING CODES.
Bin wrenchin' on the Yota's since '84
2000 Tundra SR5 4.7 Ex Cab
2010 Camry LE 2.5
Cheers!
