opinions needed on my oil leak repair estimate - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2011, 07:35 PM   #1 (permalink)
tylerho's Avatar
View tylerho's Photo Gallery
4th Generation opinions needed on my oil leak repair estimate
Back a couple of months ago I put out a post out about my car leaking oil onto my subframe. I just found out that the Valve cover gasket was causing the leak. I am not capable of doing this work. My family trusted mechanic put out a quote to fix the leak.
He said that I need a new valve cover gasket and if i wanted to make sure I could also replace the oil pan gasket since i still have the original that was never replaced and I am due for an oil change soon.
The grand total he told me is $250. That includes:
OEM valve cover gasket
spark plug cover seals
and the oil pan gasket.
For the oil I was planning to go with the Mobil 1 Extended Performance that goes up to 15k, I am moving closer to my school's campus and I could walk everyday.
What are you opinions about his pricing and Mobil 1 Extended Performance.
Hope to hear what you guys think of the price my mechanic gave me.
Thanks
tylerho is offline   Reply With Quote
Old 05-23-2011, 08:06 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Thats not bad.
It's possible the oil pan leak could just be oil coming down from the valve cover leak. What engine do you have?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
Old 05-23-2011, 08:07 PM   #3 (permalink)
TN's Mad Chemist
projektvertx's Avatar
Gameroom cash: $568901
iTrader Score: 20 reviews
View projektvertx's Photo Gallery
Is this a V6? If so, that seems very well priced considering the work involved and the fact that he's supplying the parts. I'm not a big fan of extended oil change intervals, like 15K miles. I would run a synthetic, good filter, and push 5K or 7.5K miles, depending on the car's usage cycle (city vs. highway).
1995 Toyota Camry V6 LE-6M1 250K Miles, Fun Car
1997 Acura RL-Gone
2007 Acura RL SH-AWD, Technology Package, Opulent Blue Pearl- Fun Car/Daily Driver
projektvertx is offline   Reply With Quote
Old 05-23-2011, 08:12 PM   #4 (permalink)
tylerho's Avatar
Originally Posted by pmesfun View Post
Thats not bad.
I have the v6 1MZFE. I forgot I have to supply my own oil and filter. I might just use Mobil 1 High mileage.
Old 05-23-2011, 08:16 PM   #5 (permalink)
TN's Mad Chemist
At 250$, that's a REALLY good deal on the 1MZ. Keep in mind however, that the oil pan is Toyota's "Form In Place Gasket", or FIPG. Since the mechanic will need some for the valve cover gaskets either way, I would pick up a tube for him
As Pmesfun mentionned, the valve covers may be mocking as an oil pan leak. There is also a gasket between the oil filter adapter and the engine block that when it fails, may also mock as a oil pan leak
1997 Acura RL-Gone
Old 05-23-2011, 08:30 PM   #6 (permalink)
tylerho's Avatar
Thanks for the heads up I'll pick some up for him tomorrow. Hes been my families mechanic for a really long time now and he said he'll give me the best price possible.
99 Camry V6 135k miles
Bridgestone Potenza re970as Pole Position
Old 05-23-2011, 08:46 PM   #7 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
$250 is a very good deal. However, your mechanic should use new valve cover bolts too, or add a couple of washers to old bolts like one member did in a thread (see message #5 below). The mechanic should also reseal the semi-circular plugs.
http://www.toyotanation.com/forum/sh....php?p=3030004
Getting to the rear bank on the V6 is always a problem. However, the oil pan on this (and many other engines) are two-piece. There is an upper pan and a lower pan. The lower pan is no problem, but the upper pan requires removing the exhaust pipe directly under, which is likely the hardest part of all because of seized nuts and snapped studs. If he thinks the lower pan may be leaking then not doing the upper pan is doing half a job.
Thanks
Old 05-23-2011, 08:47 PM   #8 (permalink)
Avy
Mobil 1 Super High Mileage is on sale @ $2.49/qt at Oreilly's until tomorrow.
This is the front valve cover gasket I'm assuming. The coolant needs to be drained because the upper rad hose needs to be removed. Consider picking up a gallon of coolant, or if the current coolant is not that old you can reuse.
99 Avalon XLS-149k
99 Lexus LS400-88k
