"Most importantly, I noticed a slight squealing sound when climbing the hill coming from under the car on the passenger side."
That noise may be unrelated to your original problem. That's where the 2 accessory belts are located, assuming you have the 4 cylinder 5SFE engine. See if you can have someone rev the engine in park for you (don't overrev it), while you listen in that area for any belt squeak. Also, inspect the belts for glazing and cracking on the sides that contact the pulleys.
"I will try changing the plugs first as they're 5+ years old. Cap, wires, and rotor have also been changed 5+ as well as a new coil about 6 years ago."
How many miles does that equate to? Also, are these OEM or aftermarket parts?
Mike
