tire size q - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2011, 10:05 PM   #1 (permalink)
View njcamry's Photo Gallery
tire size q
hey all, got a 97 camry with tire size 195/70/14...i've had 195/75/14 on the rear 2 for 2 yrs without any issues, even though they're bigger (got em free)...ive been scared to put them on the front because some1 warned me bigger tires shouldnt be on the front, now ive got 2 more of those for free and am wondering if they worked on the rear, why not front, any thoughts? thanx!!
njcamry is offline   Reply With Quote
Old 05-25-2011, 05:22 AM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $201200
View Tom 2000's Photo Gallery
It will work in the front, but your speedometer/odometer will be off and the handling will be sloppier.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 05-25-2011, 11:27 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
it wont make much of a difference. i say run the free tires (as long as both of the front tires are the same size) and know that your speedo will be off by 3.1%, so when your speedo says 60mph, you will be going about 62.
Old 05-25-2011, 07:41 PM   #4 (permalink)
thanx..ill try them, seems theyre safe enough
Old 05-26-2011, 04:23 PM   #5 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
With two different tire sizes, you have a possibility of ruining your ABS system, so if I were you I'd get those other two tires on stat.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 05-26-2011, 10:42 PM   #6 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260140
View Yuko's Photo Gallery
That is very true. Late model vehicles with ABS, Traction Control, VSC, ESC, VDC, and AWD systems such as Subaru's required correct spec size tire on all four corners to function safely.
Having said that, ABS and TC wasn't standard on the 97 Camry. The only real problem with a taller tire is a slightly slower acceleration.
"Yūko" 2001 Camry 5S-FE/A140E @ 90k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 156k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 2K
Yuko is online now   Reply With Quote
