Cold Engine - Won't Start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-24-2011, 10:33 PM   #1 (permalink)
View zildjianzbtpro's Photo Gallery
4th Generation Cold Engine - Won't Start
Ok, here is the deal. When i go to garage in the morning to warm-up my 97 Camry (2.2L i4), it won't start up on its own. Every time I have to kind of rev it with acceleration pedal, then it will launch. It only happens when its cold. Sad part is that I have remote start installed. And when I try to start it up remotely, seems like starter would start then it makes weird noise like a jet startup, then I turn it off immediately. I think it started doing this when I installed an air cold intake. Now I drive without cold intake, just regular filter, but the problem wouldn't go away. Any thoughts?
zildjianzbtpro is online now   Reply With Quote
Old 05-24-2011, 10:38 PM   #2 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Sticking starter solenoid plunger. Probably caused the starter gear to be engaged to the flexplate.
Autozone and maybe other parts stores offer free testing.
http://www.autozone.com/autozone/ino...s/services.jsp
For the cold start problem check the engine coolant temperature sensor (2-wire deal). See message #47 of this thread:
ECT switch, sensor or sender ? planning to replace
Maybe it's time to clean the IAC? If you do you should disassemble it.
5sfe IAC Removal (lots of pictures)
