99 Camry 4cyl crank pulley bolt... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2011, 12:34 PM   #1 (permalink)
View navalfan's Photo Gallery
Question 99 Camry 4cyl crank pulley bolt...
Hi all,
Is the crank pulley bolt on a 99 Camry 4 cylinder engine lefthand or righthand thread? Or, will I have to turn it left or right to loosen it?
Thanks!
Paul
navalfan is offline   Reply With Quote
Old 05-25-2011, 12:42 PM   #2 (permalink)
View dave255's Photo Gallery
It is standard thread, turn left to loosen
dave255 is offline   Reply With Quote
Old 05-25-2011, 12:43 PM   #3 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
Right hand, conventional thread, you turn it counter clockwise to loosen. Use the "starter bump" method to remove it, don't use an impact wrench it is not good for the crank bearing.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 05-25-2011, 01:41 PM   #4 (permalink)
techtalk's Avatar
View techtalk's Photo Gallery
standard thread. clockwise= tight. counter= lose.
if you have an impact gun you can zap it off.
you can also use a chain wrench to keep the crank from moving and
use a braker bar to get it lose
techtalk is offline   Reply With Quote
Old 05-25-2011, 02:48 PM   #5 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Luckily you didnt cross thread the bolt and then using a 1000ft lb impact to get it off because you 650lb impact wouldnt work, then tapping the crankshaft out to 9/16" -18 Threads and finding out that its really really hard to find a 9/16 - 18 bolt anywhere in houston, so you bend the original bolt back straight and using a die tap the old stripped out bolt with the 9/16" - 18 Die. By the way Lucky that you didn't have to buy a $125.00 tap / die set because you needed one tap.
Just saying, your lucky. LOL
Actually that whole story was what happened to me. The actual reason that it fucked the threads up on the crankshaft was because my Harmonic balance pulley stripped the threads on the crank out and I didnt realize it until i jammed the bolt tight in there.
