Extended Warranty for 2000 Toyota Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2011, 08:25 PM   #1 (permalink)
View CROSAIRS's Photo Gallery
Today, I bought a 2000 Toyota Camry LE with 88000 Miles on it. Please suggest a Good Extended Warranty that I can take for Cleveland/Columbus areas in OHIO. I plan on driving this for 60000 miles. Please kindly let me know.
Thanks
2008 Honda Civic Si
2005 Lexus ES 300
2000 Camry LE
CROSAIRS is offline   Reply With Quote
Old 05-25-2011, 08:45 PM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
No ones gonna give you a warranty on a 10 year old car. If they do its gonna be one of the joke scam warranties that dont cover anything that breaks.
Its a reliable car. You dont need a warranty. Take good care of it and it will last 200k miles. Dropping 1000 on a warranty with a 500$ deductible would be just stupid, since nothing costs more than 1500 to fix on this car.
carsrus is offline   Reply With Quote
Old 05-26-2011, 10:03 PM   #3 (permalink)
View slavie's Photo Gallery
If it's got 88k on it and you're only planning to put another 60k, I wouldn't worry about warranty. I don't see anything major breaking until your tranny could start to go around 160-170k (that's when they usually go...) Even that is just $1300 to rebuild.
Unless the warranty is less than $100/month with no deductible, if is not worth it. Just make sure you do proper maintenance, and you'll be all set.
slavie is offline   Reply With Quote
Old 05-26-2011, 10:25 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
if timing belt hasn't been done recently then it's up for timing belt change and all the stuff involved (WP, seals, gaskets, coolant, thermostat, belts, etc.). easily $500 at local shop with cheap parts of even more with OEM parts.
minor tune up would be a good idea too (A/F filters and spark plugs, get new wires if you suspect problems with old ones).
I also recommend all other fluids flush (transmission, differential, brakes, power steering) and an oil change with some decent oil filter
there is a bunch of minor stuff also which you can do, but don't have to like new rad cap, tank cap, PCV valve and grommet, rubber hoses replacement, etc.
