There is an A/C amplifier for these systems (see pic) but I would check to see if there is refrigerant in the system first. I believe if it is low or there is none, the system will simply not engage the compressor, could be wrong though I know very little about A/C systems.
edit - you can check to see if the compressor clutch is working by using this procedure.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
