Big Thanks! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-30-2011, 12:53 PM   #1 (permalink)
View pecanfmr's Photo Gallery
Big Thanks!
Here's the story,
I was getting DTCs 12 & 13 and the car would die suddenly after getting warmed up or after driving somewhere it wouldnt start after sitting for a little bit. I would let it sit and it would eventually cool down and start again. The distributor had been replaced within the last 2 years. All connections checked out with the MM. I replaced the coil which had a crack in it and that did not fix the problem. One of the common threads between the 2 codes was the NE- and NE+ resistance. I took my MM with me and waited for the car to die, which didnt take long. Even though the distributor was fairly new it turned out that the Ne- and Ne+ connection from the distributor would crap out when it got hot. New distibutor, no more problems.
The only discrepancy I found was with the primary resistance of the internal coil. I was getting .8 ohms for the old and new one instead of .4 - .5 as stated in the Haynes manual and what I found on forum threads.
Thought I would post my experience to possibly help someone in the future. Thanks again to everyone for all the helpful posts!
pecanfmr is offline   Reply With Quote
The Following User Says Thank You to pecanfmr For This Useful Post:
drhardway (06-01-2011)
