Both NAPA and O'Reilly should carry
Gates belts and hoses. Ask for those. I get
Fel-Pro gaskets at O'Reilly and Autozone. Check out the Autozone rewards program. So you should be fine.
Use OEM Toyota thermostat (because the
Stant OE type is a special order item locally, and the typical local stats are lower grade).
Toyota Aisin water pump (probably ~$90) and
Toyota Red coolant (~$30) are the things you need from the dealer. You may want to pick up a
new tensioner spring as well while you are there ($5 or so). It's probably not needed, but they had updated it because of some loose belt problems. So I'm not sure if you have the updated spring or not.
If you plan to get a water pump from O'Reilly get the Master Pro (~$35) with a lifetime warranty. The picture looks like a Japanese aftermarket brand, NPW. But of course the source may change at any time. This is probably the same pump under NAPA's Alstrom (a reboxed NPW), but NAPA's price is similar to Toyota's - so no sense going to NAPA when you can get an OEM pump for about the same price.
Here is another way to hold the crank and loosen the bolt:
home made tool to tighten camshaft sproket nut
Also check Autozone's free loaner program if you need a harmonic balancer puller, spark plug tube nut socket (=axle nut socket), or torque wrench. You will also need dabs of RTV for semi-circular plug joints and at the base of the cam cap when installing the valve cover gasket. Make sure to retorque the spark plug tube nuts after a few driving cycles because they like to loosen up. And if you receive the metal/rubber water pump gasket then make sure the block surface is clean and flat. If you receive the paper gasket, then buy a tube of Permatex water pump RTV, and use leftover dabs of it on the valve cover joints specified.
The following is an updated list I gathered yesterday for 5SFE (
double check applications). The prices were from rockauto, so local prices will be higher:
GATES K030295 Micro-V AT Power Steering Belt $5.14
GATES K050435 Micro-V AT Alt/AC Belt $14.10
FEL-PRO TCS45920 Crankshaft Front Seal Set $5.10
FEL-PRO TCS45641 Camshaft Front Seal $3.66
NATIONAL 221820 Polyacrylate Oil Pump Shaft Seal $2.86
GATES TCK199 (1 Belt, 1 Tensioner, 1 Idler) Timing Belt Component Kit
$52.89
STANT 48278 180° w/Jiggle Pin OE Type Thermostat $10.94
AISIN WPT010A Water pump w/o housing $30.79
FEL-PRO VS50304R1 Valve Cover Gasket Set w/Spark plug tube seals
$18.26
Subtotal $143.74
Shipping about $20
Good luck and keep us posted!!!
Originally Posted by m50
I have one more question. I might start on this job this weekend could I use aftermarket parts from OREILLY or NAPA or is that not a good idea?
thanks RB
