2001 Camry:Changed rear struts, alignment necessary? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-01-2011, 06:29 AM   #1 (permalink)
View jmc55ma's Photo Gallery
I just changed my rear struts. is a 4 wheel alignment necessary?
jmc55ma is offline   Reply With Quote
Old 06-01-2011, 06:57 AM   #2 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
No. Theoretically yes, on the front but the rears not so much.
As long as you didnt touch any bolts other then the sway bar link and the upper and lower strut bolts your fine. If your doing front never loosen up the tie rod or ball joint as that will play around with the alignment.
carsrus is offline   Reply With Quote
Old 06-01-2011, 07:04 AM   #3 (permalink)
carsareus, thanks for the reply. i did not do this job myself I had it done at a independant shop. All they did was unbolt the struts and put in the new ones with the original springs. I test drove it on the highway and the steering wheel was still straight and no shimmy or drift. i assumed it did not need to be realigned.
