need help asap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-02-2011, 10:24 PM   #1 (permalink)
View ZachP's Photo Gallery
Unhappy need help asap
Im trying to change my fuel filter and i cant get the lower flare nut loose to relieve pressure
any suggestions?
also, this is my first time doing this, so if im doing anything wrong please correct me
ive gotten most of the stuff out of the way now im just trying to get it loose, i opened my gas cap and a little pressure let out. also when im putting the new one in is there anything i should know? like lube it up or something?
thank you,
Zach
ZachP is offline   Reply With Quote
Old 06-02-2011, 10:34 PM   #2 (permalink)
Gameroom cash: $168100
View sam333's Photo Gallery
Make yourself alot of room ( sounds like you did ) . Get a flair nut wrench( if you round it off you will not be happy) .Make sure you clean any rust /dirt / grease before you try to loosen it. change any compression washers.
sam333 is offline   Reply With Quote
The Following User Says Thank You to sam333 For This Useful Post:
ZachP (06-04-2011)
Old 06-03-2011, 07:17 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140495
throughly douse that connection with PB blaster and let it sit for 30 minutes to help break the bond. try removing the bracket holding the filter in place so the filter can spin easily. you really dont want to round off the nut or twist the fuel line.
The Following User Says Thank You to ghettosled For This Useful Post:
ZachP (06-04-2011)
Old 06-03-2011, 02:44 PM   #4 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
you have to use 2 wrenches. 1 must be flare nut wrench for turning the nut (14mm was it?) and the other can be a regular (19mm if I remember right) open end wrench to support the filter body in place.
you have to position 2 wrenches so they form like a 1 or 2 o'clock position, minding the perspective (you are looking at the flare nut from top, so it's upside down) and make sure you will be turning the nut in correct direction (clockwise when looking from top).
with use of of 2 wrenches together with one (or both) hands it will be easy to loose it. you just need to sort of close them together like scissor blades, since supporting wrench won't move, the flare nut will turn.
you only need to make sure, you position them right, so you do not tighten the nut even more.
worked for me on 2 cars, once at 80k miles, other time at 124k miles with no problem and both filters were original factory ones.
The Following User Says Thank You to fenixus For This Useful Post:
ZachP (06-04-2011)
Old 06-04-2011, 12:48 AM   #5 (permalink)
we eventually got it with the help of half a can of deep creep, my bolts were rusted. what a pain though, a 15 minute job took 1 and a half days and 2 trips to autozone, hahaha we suck.
new question, ill probably end up posting in a new thread though:
is there a way to delete the automatic headlight sensor? so i just use the switch, because my buddy and i like to go stealth mode when avoiding the fuzz late at night, cause basically right now the switch is useless, unless in day time, or when my engine is off. ('01 cam LE)
thanks,
Zach
