HELP.!! GAUGE LIGHT ARE NOT WORKINg.! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2011, 09:33 AM   #1 (permalink)
View astatcamry956's Photo Gallery
Unhappy HELP.!! GAUGE LIGHT ARE NOT WORKINg.!
ok well i ordered some 194 leds for my car from ebay....only problem is that when i insert the Led light bulb and insert it in the circuit...the light doesnt turn on at all. i was thinking maybe it was the Led's.? so i went to Autozone and bought 2 pack of silverstar 194 light bulbs. so i get home and i insert them in the socket thing then on the circuit board and still nothing i even tried putting the OEM back on it, but it doesnt seem to light them up...the only ones that light up are the ones that i havnt taken out the bulb and have the OEM bulb in it.
Can ya help.? why isnt niether my LED bulb or my silver star bulb working.?
astatcamry956 is offline   Reply With Quote
Old 06-04-2011, 10:15 AM   #2 (permalink)
Lighting Specialist!
iovaykind's Avatar
Gameroom cash: $480582
iTrader Score: 8 reviews
View iovaykind's Photo Gallery
Did you make sure all the wires were plugged back in? Not only do you have to plug in the wires to the back of the gauges, you also have to plug back the trim adjustment knob found in the lower left hand side of the trim. So its a little annoying, needing to keep the whole trim piece there in order to make sure the lights are working but that's the problem I found with mine not working.
iovaykind is offline   Reply With Quote
Old 06-04-2011, 04:12 PM   #3 (permalink)
yeah i made sure everything is connected right, the knob is at the brightest it can go. but they just dont light up.....maybe the LED lights isnt making any contact with the two lil wires in the wedge...but it should of worked with the Silverstar ones..so now none of the lights works and im lightless for my cluster
here are some pics so u can see the lights that i bought.
Old 06-04-2011, 05:56 PM   #4 (permalink)
iovaykind's Avatar
Well first.. even after you fix it (sorry I can't seem to tell the problem) get some LEDs that look like this:
The ones you have won't light up the dash evenly because they're all forward facing. Check fuses? That's the last thing I can think of.. sorry
Old 06-04-2011, 06:01 PM   #5 (permalink)
3rd Generation
Alright lemme check on the fuses maybe its that..havnt checked that, but hopefully its that cause dont wanna drive aroung without cluster lights....ill get back at ya to see if it was a fuse.
Do u know was fuse it is.?
Tags
194, bulb, cluster, gauge, light
