White Smoke from Engine Bay - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2011, 06:42 AM   #1 (permalink)
al1
View al1's Photo Gallery
1998 V6 Camry with 1MZ-FE Engine.
Just changed rear valve cover gasket. First time it didn't seat properly (gasket got torn out of groove during re-fitting) and leaked a lot of oil. Lots of white smoke from engine bay while driving caused me to notice this.
Did it again (checking gasket was on properly before bolting down cover) and oil leak has gone.
There is still a small amount of white smoke coming from the engine bay after driving. Could this just be residual oil from the leak burning off or a more serious problem? Some (not much) coolant also leaked while I was removing the throttle body to make it easier to get the intake off, could this be a cause?
Thanks
al1 is offline   Reply With Quote
Old 06-05-2011, 03:10 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
Yes, the white smoke is most likely the oil burning off, mine still smoked for a short time after I changed the gasket.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
al1 (06-05-2011)
Old 06-05-2011, 03:41 PM   #3 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
spray it with engine degreaser and wipe clean after a few minutes. may need to do this a few times, from under car.
The Following User Says Thank You to fenixus For This Useful Post:
al1 (06-05-2011)
