Which directions to Advance/Delay timing on Camry 4cyl, 94 ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-05-2011, 08:23 PM   #1 (permalink)
Camry: 94-I4 and 94-V6
View sintox's Photo Gallery
Question Which directions to Advance/Delay timing on Camry 4cyl, 94 ?
HI all,
Last year I advanced my timing 2-4 degrees (or something close to that).
Now I would like to do the inverse, delay the timing by the same amount.
I remember there are two bolts to loosen. Then the flange (on the left-hand side of the distributor ) can be moved up/down (Up means: clock-wise, Down: counter-clockwise).
The problem is I now forget Advancing the time is to move Up or Down the flange (turn distributor clockwise or counter-clockwise).
I'm standing besides Left-front wheel, on the Driver-side of the car.
Thank you for your guidance.
EDIT: I think I got the answer: turn distributor Clock-wise is to advance ignition timing (leaner, but possibly higher chance to damage old and original head).
turn counter clock-wise 3-4mm : delay timing.
sintox is offline   Reply With Quote
