TPS issues
I've got a '96 Camry with a 2.2l. It developed a delayed 2-3, 3-4 shift so I took it to a trans shop. There was no check engine light but they said the throttle position sensor was malfunctioning, thus affecting this. I replaced the TPS according to Chilton and now have a cel showing codes 121, then 120 after clearing. It seems it may be an adjustment issue since the scanner shows TPS value at 2% for closed throttle while running. Any ideas? If adjustment, what is the proper procedure and what should value read? Thanks in advance!
