Will 10mm and 12mm spacers clear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-06-2011, 06:56 AM   #1 (permalink)
akcc's Avatar
View akcc's Photo Gallery
Canada Will 10mm and 12mm spacers clear
Would 10mm and 12mm spacers with hubcentric clear on a camry 1999 with camry se 2004 16" mags. Does it require any fender rolling? Would there be any clearance issues in the front?
Also what are the disadvantages of having this size of spacers?
-ps - I have extended studs already (50mm studs)
Toyota Venza 2010 AWD v6
OEM HID + 6000k D4S Bulbs
XM Platinum Series H11 8000k Digital HID
Toyota Camry 1999 XLE v6
XM Platinum Series Bixenon 6000K 55w Digital HID
akcc is offline   Reply With Quote
Old 06-06-2011, 10:21 AM   #2 (permalink)
Jonate's Avatar
Gameroom cash: $257150
View Jonate's Photo Gallery
Im running 12mm spacers on my 01 camry, on an 18x9.5 wheel on the rear. I had to roll and pull the fender to make it fit, and yet it still rubs (i think thats because the suspension is so soft). But in your case, a stock wheel shouldnt rub. Im thinking it should be fine. On the front i have an 18x8 with the spacers and I didnt have to do anything to the fender to make them fit. Clearance is all good in the front.
Call Pizza Hut, and Tell'em I got Deep Dish
Jonate is offline   Reply With Quote
Old 06-07-2011, 12:53 AM   #3 (permalink)
akcc's Avatar
So basically as long if it is Oem mags there shouldn't be a problem correct? Unless is there a limit of tire size not to go over like 235 or 245 or even 255?
Old 06-07-2011, 08:55 AM   #4 (permalink)
Jonate's Avatar
Exactly, just don't go over 235 on the tires and your good. Where did you find the spacers? I had to order mine and have them made. iIt was a mess, and expensive too.
Old 06-07-2011, 02:26 PM   #5 (permalink)
akcc's Avatar
Cool cool! Really appreciate the advice! I got my spacers from a local automotive supplier, liquidationsdemags, same for my studs, really cheap too! Under 30$ for studs and under 20$ for spacers
Old 06-07-2011, 05:25 PM   #6 (permalink)
Jonate's Avatar
Dang thats wassup you got a good deal. No prob, anytime.
