Rear rotor will not go back on (star wheel adjusted) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 06:31 AM   #1 (permalink)
Gameroom cash: $148300
View SilverSoarer's Photo Gallery
Vehicle has rear disc with parking brake shoes.
Replaced parking shoes with new -verified parking cable, star adjuster, etc.
Replaced with new rotor.
Adjusted star wheel to minimum circumference of parking shoe brake.
Rear rotor inside diameter just barely sits on edge of parking brake shoe - the rotor will not mount on to wheel lugs - clearance is too tight with new parking brake shoes. In other words the rear rotor is caught on the brake shoes.
What can I do ?
SilverSoarer is offline   Reply With Quote
Old 06-07-2011, 08:40 AM   #2 (permalink)
Born to Drive
EEngineer's Avatar
Gameroom cash: $426953
View EEngineer's Photo Gallery
loosen your e-brake cable near the handle or foot pedal
My Once Beloved Camry
Rest in Peace
NEW ES300 5SPD SUPERCHARGED BUILD THREAD
EEngineer is online now   Reply With Quote
Old 06-07-2011, 01:50 PM   #3 (permalink)
View holmesnmanny's Photo Gallery
Atleast you didn't try taking your rotor off with your e-brake on like I did once.
1991 Camry LE V6 Automatic
holmesnmanny is offline   Reply With Quote
Old 06-07-2011, 02:39 PM   #4 (permalink)
2002,5SFE
View houra's Photo Gallery
houra is offline   Reply With Quote
Old 06-07-2011, 03:01 PM   #5 (permalink)
Thanks for all the suggestions.
The issue seems to be clearance with new brake shoes and new rotors --there is no room even with parking cable detached and shoes at full retraction (minimum diameter) using star wheel adjuster -- for the rotor to fit over them.
Double checked the cable, brake hardware, and the centering of the brake shoes.
Short term, I removed the parking brake shoes (and associated hold down springs) to get the rotor on.
As a last resort machine the inside drum of the rotor 0.5-1 mm to get them to clear --or sand down the new brake shoes to take off some friction material.
Any other ideas or hints ?
Old 06-07-2011, 03:21 PM   #6 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
omg, now i just remembered a few weeks ago, i was trying to replace rotors on my solara v6, did the front, then when i was trying to remove the rear, i remove all bolts, and the rear disc rotor was actually loose, but i couldn't pull it out, so i just put everything back. my solara is a stick shift, it is my habit to pull the hand brake while parked, i don't remember i ever release the emergency brake, silly me
http://mysite.verizon.net/vaio338168/avator.jpg
2002 2AZ-FE, LE Phantom Grey Pearl, Retrofitted with LS430 Projectors on SE Headlights. Aftermarket Foglight
bronzemaxell is offline   Reply With Quote
Old 06-14-2011, 09:22 PM   #7 (permalink)
Just confirmed it's the centering of the brake shoe.
I used Raybestos brake shoes - although they look identical to the Toyota ones - there may be minute differences that make them sit different.
