Someone help please with P0420 code - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 07:00 PM   #1 (permalink)
View joeyl's Photo Gallery
Unhappy Someone help please with P0420 code
recently bought a 1998 toyota camry 4 cylinder. check engine light came on soon after with a
P0420 code. then came low idling followed by white smoke every so often. now today while driving it just shut down on me. wont start back up either. now im stressing and would like a little help. if anyone has any idea what it could be and how to help, it would be much appreciated! i am on a very small budget too
joeyl is offline   Reply With Quote
Old 06-08-2011, 01:12 AM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3627250
Hello, and welcome to TN! I'll move your thread over to the Camry forums so the members there can help you out. You'll also want to use that forum's search feature to locate any past threads dealing with that error code. Good luck!
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is offline   Reply With Quote
Old 06-08-2011, 07:03 AM   #3 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
Your code is as follows:
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
The white smoke sounds like a head gasket to me, but there are other things you should look for to diagnose that. Has the exhaust had a sweet smell, been white before? Have you been losing coolant (unexplained)? How does your dipstick look (dark like oil or milky/frothy like oil mixed with coolant)? What is your compression like (test all four cylinders)? Has the car been overheated anytime in its history (especially if overheated and then cool fluid put in while hot)? Any mechanic worth his salt should be able to diagnose a head gasket if that is the problem - hope it's not.
Tracy Faulkner
ycartf is offline   Reply With Quote
