blowing smoke on start up - burning oil - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2011, 08:26 PM   #1 (permalink)
View mtdidomenico's Photo Gallery
USA blowing smoke on start up - burning oil
My 2001 Solara started burning oil and blowing smoke on start up about 6 month ago. I continue to add new oil as the oil light comes on. If I add less than 1 qt when the oil light comes on, it helps a little with the start up smoke.
I tried some of the additives from Autozone but no luck.
Aside from an engine rebuild, Any advise?
Thanks
Mike
mtdidomenico is offline   Reply With Quote
Old 06-07-2011, 08:56 PM   #2 (permalink)
Gameroom cash: $303755
Yes, stop waiting for the oil light to come on before adding oil. When the oil light comes on while driving or stopping with the engine running, it means you have lost all oil pressure. At this time you are putting an extreme amount of wear on the engine. Check the oil level on a regular basis and add oil to bring the level to the full line. This will buy you some time, but if the light has come on a few times there is extreme wear on all the moving parts of the engine and you are probably looking at a new engine. Which engine does the car have, I4 or V6, and how many miles are on this car/engine?
Mike
Old 06-08-2011, 07:34 AM   #3 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
Ditto what Mike said. Waiting until the oil light comes on to add oil is liking waiting for flys to circle your butt to wipe it.
Tracy Faulkner
ycartf is offline   Reply With Quote
The Following User Says Thank You to ycartf For This Useful Post:
96ToyoCam164K (06-08-2011)
Old 06-08-2011, 09:52 AM   #4 (permalink)
Gameroom cash: $470955
View carsrus's Photo Gallery
If its that bad, fill it up with some THICK oil. 10w40 at a minimum, High Mileage Conventional.
If that doesn't slow it down just up to 20w50 diesel oil and drive it till it dies. Make sure your not leaking oil in addition to the burning.
Basically, the thicker the better. I wouldn't waste money on additives as they just thicken the oil for the most part.
carsrus is offline   Reply With Quote
Old 06-08-2011, 10:18 AM   #5 (permalink)
Its the V6 version with 130K on it.
If I go the rebuilt engine route, any warnings I should look for in terms of people trying to stick it to me?
Old 06-08-2011, 11:50 AM   #6 (permalink)
The best advice I can give you now would be to ask friends or relatives if they can recommend a mechanic that they trust.
Mike
Old 06-08-2011, 03:20 PM   #7 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
Mike
yeah the 4cylinder oil pressure light comes on when the car is below 4psi of pressure. Not good though! lol
Old 06-08-2011, 09:31 PM   #8 (permalink)
molson.david's Avatar
Gameroom cash: $293553
View molson.david's Photo Gallery
like was said above:
check your oil level at least ones every 3-4 days. add oil as needed.
use 10-40 oil or even thicker.
don't know what additives you using, I will recommend Restore Engine Restorer
http://www.restoreusa.com/Engine_Restorer.html
I've seen it at autozone and even walmart.
if it will not help-nothing will.
good luck.
IndianaBorn gen7 LE.
For sale gen 6:
MdxTSXr black shrouds 5K retro
OEM key with transmitter
2.4 transm.filter+gasket+WS.
2.4 K&N drop-in+cleaner and oil
molson.david is offline   Reply With Quote
Old 06-08-2011, 09:46 PM   #9 (permalink)
Died around age 230, XXX
96ToyoCam164K's Avatar
View 96ToyoCam164K's Photo Gallery
LOL, I've never heard that before...I thanked you for that LOL.
Wow, this thread made me feel better. My car burns oil a bit but never has the oil pressure light gone on. Not to jinx or brag...but wow. That's just not good. And 130,000 miles isn't that much (even though I bought mine at that mileage and had BAD oil leak/burn and still does :-( So if I can go another 100,000 miles like that I'm sure your 99 can too.
Def. switch to high mileage if you haven't already. Any brand will work but Penz, Vav, Quaker state, Castrol last a bit longer than generic.
I just bought some 10W 40 today and can't wait til Friday to put it in and see what happens. I used to use Lucas, and you can if you want but from what people have said it just thickens it. The bottle even says 100% petroleum.
96ToyoCam164K is offline   Reply With Quote
Old 06-08-2011, 11:54 PM   #10 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Aside from oil consumption is the engine running smooth? If so I'd remove the valve cover and inspect things underneath. The 01 belongs to the sludge maker generation. If it's not leaky stem seals or piston rings, then maybe it's heavily sludged up.
If you want to rebuild it, besides friends' recommendations try an AERA member shop. See if you can find a shop that participates in racing. Some of the shops are duds however.
http://www.aera.org/member-services/member-locator/
Tags
oil, smoking startup, solara
