Originally Posted by carsrus
First check the two pipes that go under the exhaust manifold. Maybe you'll get lucky and its coming from there.
Well, you were almost right, and I'm really pissed off at my lousy diag skills on this one.
I went back in as far as getting both the timing covers off, and, lo and behold there wasn't a trace of water leakage anywhere behind the covers (no oil leakage either, so that makes me real happy). So, I started hunting around so more, and found a little pink trail (whatever else you can say about Toyota Red, it definitely leaves a trail) coming down the front of the A/C compressor and thence to the bottom of the timing cover. Tracing it the rest of the way back, it turns out there was a tiny leak from the thermostat gasket. Just my luck it all went forward instead of puddling against the engine like it usually does on a t-stat or bypass pipe leak. Since I'd just replaced the thermostat 3 years back, I hadn't even messed with the t-stat, but I guess while I was dinking around with the rest of the water pump, I managed to piss off the t-stat gasket. Weird.
After replacing the gasket, things are looking a lot better. Since my system is still in the "get rid of the last few air bubbles" stage, I'm not 100% certain there isn't a tiny leak still lurking, but I think this got it.
Thanks for all the suggestions, and I hope this tale of stupidity helps someone else along the way.
