When to Change Struts?????? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2011, 01:22 PM   #1 (permalink)
View gbeers's Photo Gallery
I have a 2001 Camry Solara V6 Auto with over 125K miles. I bought her brand new and she sleeps in the garage every night. I was wondering what the mileage was when others have had to change their struts. I know there is a lot variability from car to car based on location and how they drive etc. but was just trying to get a consensus. I inspected them and they seem fine. No leaks, boots are not cracked and the coilovers look fine. The ride seems softer and the bumps seem to hit harder. Even though I mostly use my Tacoma during the winter, New England roads are horrible any time of the year. If you have seen them NE frost heaves and pot holes you know what I mean. I do drive the Solara in the winter on nice days because of gas mileage and to keep things moving.
gbeers is offline   Reply With Quote
Old 06-08-2011, 01:53 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
When the struts start to leak, its time to replace them.
Some people replace them before this happens .. the car will start feeling like its floating when going over bumps. If it feels like its floating while going over bumps, its a good indication that they will be leaking soon
The Following User Says Thank You to Mister_Perkins For This Useful Post:
gbeers (06-08-2011)
Old 06-08-2011, 01:57 PM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $350153
View BMR's Photo Gallery
You'll get widely varying opinions on that. They slowly degrade over time, so it depends on how "like new" you want to keep the suspension working. Barring a major failure, they'll last a long time if you're OK with less than optimal ride/handling.
On my Camry, the rears failed suddenly at around 140k miles. The back end would bounce numerous times after going over a speed bump or swell in the road. The fronts I just replaced about 10 months ago with ~300k miles on 'em. They weren't leaking or showing any signs of gross failure. But the handling was getting a little "nervous" going over ripply pavement at freeway speeds so I replaced them. Both of them were still holding some of their gas charge when I put them in the dumpster.
BMR is online now   Reply With Quote
The Following User Says Thank You to BMR For This Useful Post:
gbeers (06-08-2011)
Old 06-08-2011, 02:06 PM   #4 (permalink)
Yeah i agree with that. Everyone has an opinion on when you should change struts.
(Edit: Most States) says that if they are leaking, you will fail an inspection. But if the ride quality is bouncy, or floaty feeling it will pass. (edit: In Texas, as long as it drives down the road and it passes emissions if prior to 96, it will pass. lol)
I personally dont like my car all bouncy like that, so i change them when they start riding like crap even if they arent bad
Old 06-08-2011, 06:41 PM   #5 (permalink)
View jmc55ma's Photo Gallery
I changed my front struts at 120000 and my rears at 170000 because they were leaking. The new struts were monroe sensatrac which gave a firmer ride but i just dropped the tire air pressure from 32 lbs to 29 lbs and seem to ride better.
jmc55ma is offline   Reply With Quote
The Following User Says Thank You to jmc55ma For This Useful Post:
gbeers (06-09-2011)
Old 06-08-2011, 10:34 PM   #6 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
That's probably enough reason. I'd get Monroe QuickStruts with all new components. Many TN members seem to like it. About $125 per corner on rockauto.com, with lifetime warranty.
On when to replace:
http://www.monroe.com/support/FAQ#faq3
http://www.kyb.com/vehicle/replace.php
The Following User Says Thank You to JohnGD For This Useful Post:
gbeers (06-09-2011)
Old 12-18-2011, 10:53 PM   #7 (permalink)
View AmanO's Photo Gallery
Has anyone else heard to replace the mounts whenever you replace struts?
Or is that so common of knowledge that is goes without saying?
4.0 Gen XLE V6. Minor light mods. No money for supercharger.
Driver side mirror got owned by a Taco Bell
AmanO is offline   Reply With Quote
