1998 Camry - No A/C - Need assistance - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2011, 02:46 PM   #1 (permalink)
View ultimateplayer's Photo Gallery
4th Generation 1998 Camry - No A/C - Need assistance
Brand new to the forums.
I am brought here due to an issue I would like to try and resolve myself prior to hitting up a shop.
My wife's 1998 Toyota Camry LE, with 92,XXX miles recently has no air conditioning. She failed to inform me last summer that it stopped working back around July/August. Needless to say, the rising temperatures have caused her to desire A/C again. Yet we get no indication the system works at all.
When you depress the A/C button on the dash, there is no indicator light-up, there is no compressor starting, and there is no indication the system is operating at all. There is no A/C when you depress the A/C button, only hot air, but the fan does work, so we at least had heat during the winter.
I have read through a few things which suggest it could be a blown fuse, but I havent found anything indicating which fuse it could be.
I am starting from scratch in the troubleshooting process and am currently at the point where I have identified that no electrical signal is being sent when the A/C button is depressed.
I dont have a ton of automotive experience as I have recently only done a few performance mods on my 2008 Dodge Charger, so any advice, suggestions, or tips are very much needed at this point as I try to 1. minimize the cost and 2. get the A/C working again on her car.
Thanks in advance for your assistance.
ultimateplayer is offline   Reply With Quote
The Following User Says Thank You to ultimateplayer For This Useful Post:
98CamryDvr (06-11-2011)
Old 06-08-2011, 02:56 PM   #2 (permalink)
Operator / Diesel Tech
Mister_Perkins's Avatar
Gameroom cash: $601601
iTrader Score: 6 reviews
On the 92-96 There is an AC Fuse on the right lower kick Panel Top Right corner of relay block
Old 06-08-2011, 03:37 PM   #3 (permalink)
ycartf's Avatar
View ycartf's Photo Gallery
I don't know about the electronics of it, but the compressor will not kick on unless there is enough refrigerant pressure in the system to keep the low pressure switch from coming on. That keeps you from burning up your compressor. So if you had a slow leak that lost your refrigerant (and oil), that might be part of it. It can be tested for leaks by drawing a vacuum on the system and checking to see if it holds the vacuum.
Tracy Faulkner
ycartf is offline   Reply With Quote
Old 06-08-2011, 04:15 PM   #4 (permalink)
If the compressor were low on freon though, I think the AC light would be flashing. I'm pretty sure anyways..
Old 06-09-2011, 10:55 AM   #5 (permalink)
Like a bat out of...
View swensonator's Photo Gallery
I have a 98 camry and just went through this situation. No indicator light, no compressor starting, etc. In my case it was low pressure in the system preventing it from turning on (condenser was leaking). For the record, the indicator light DID NOT blink due to the pressure being low, so low pressure is definitely a possibility.
You can test whether the pressure is low by manually jumping the pressure sensor with a paper clip. If you have a Haynes manual it describes which pins need to be connected (I could tell you but I don't have my manual with me). If the compressor turns on when you bypass the sensor, then the pressure is low and you likely have a leak.
1998 Camry LE, Acquired with 128k miles, currently 227k miles (11/11)
swensonator is offline   Reply With Quote
Old 06-09-2011, 01:42 PM   #6 (permalink)
If you do get a chance to look at the book, would you? I would definitely appreciate it.
Old 06-10-2011, 09:35 AM   #7 (permalink)
2002,5SFE
View houra's Photo Gallery
under the hood, open fuse and relay box on the right side of engine, there is a relay call 'MG/CL' change this relay with horn relay.
also check the heater(HTR) relay, it is a black and large relay.
houra is offline   Reply With Quote
Old 06-11-2011, 08:39 PM   #8 (permalink)
View 98CamryDvr's Photo Gallery
Canada Finally!!! My Camry too
Finally!! Some one else with this issue and same model/yr as you. I have been googling and lurking for 2 years to see if anyone else had this problem. I always ended up reading issues with AC problems but with blinking lights. That wasn't my issue....just no light would come on, no cold air, fan would seem to work and just didn't hear anything kick on.
I finally registered at TN now so I can join this thread (consider me a newbie at forums too).
Having no AC is killing me!! Last year I decided to bring it into a Toyota dealer to have it "looked at"... $200 later and no solution. They did offer to continue to look at it for a couple more hours to "try to" figure it out... I thought I would take a chance and hope it was just a minor issue...but I may have been silly with the first $200 but not silly enough to continue.
They did tell me that when they routed something directly it would work, but it was everything they bypassed that they would have to determine what it could be. (sorry I'm really not engine saavy for the right terms). I can call them back and get them to remind me what they wrote in their notes it that would help.
I will follow this thread to see if more solutions come up. For anyone that does post a solution can you keep in mind that I'm not engine/car saavy and post like you are writing one of those "For Dummies" manuals??
Thanks!
From Slowing Melting in the Heat.
98CamryDvr is offline   Reply With Quote
Old 06-11-2011, 09:04 PM   #9 (permalink)
Question (sorry..I know little about engines etc), If I did this : 'MG/CL' change this relay with horn relay - what should I expect to happen after 2 years of it not working, would it to start working again? Or do you think the AC button light would come on but most likely I would need a recharge?
****Update 06/12/11*** We swapped out the 'MG/CL' with the horn relay, and there has been no change. No light and no cold air.
You also mentioned "also check the heater(HTR) relay" - check it for what exactly?
Thanks for any clarification you can provide.
Old 06-11-2011, 09:08 PM   #10 (permalink)
Did you get your leak fixed? What does a garage need to do to get a leak checked? If you did get it fixed was it expensive?
I think we have a Haynes manual around the house, what section/pg should I check?
Thanks for any info you can provide.
Old 06-12-2011, 02:23 AM   #11 (permalink)
2002,5SFE
Old 06-12-2011, 08:10 PM   #12 (permalink)
I think its time to get a multimeter. Also tomorrow I think I am gonna run out and get a copy of Haynes.
Old 06-13-2011, 10:32 AM   #13 (permalink)
@ultimateplayer: Sorry I didn't get back over the weekend. Definitely follow up with the other posts as well. Before diagnosing my specific problem, I did many of the things being mentioned including checking all the fuses and relays.
As for testing whether the pressure is low: The pressure switch is attached to the top of the accumulator/drier, which is attached in front of the condenser. I don't have a scanner to upload the images from the haynes manual, but I can describe what you need to do. (I would really suggest getting a haynes/chilton manual, though. It has saved my butt on numerous occasions.) You need to unclip the connector on top of the accumulator/drier. The connector has 4 pins in the shape of a cross. You need to jump the top and bottom pins (the two that are actually touching each other) with a paper clip. You SHOULD be able to start your car and turn on the AC at this point. This will bypass the pressure switch and the compressor will turn on. If the compressor still doesn't turn on, then you may have a problem with the compressor itself.
@98CamryDrv: I did get my leak fixed. I took it in to the garage and they filled it with freon and UV dye. A couple of days later it was empty again, so I took the car back in and they located the leak. My condenser was leaking and needed to be replaced. The dealer wanted $896 for parts and labor. I bought the parts online and did the labor myself for $110. Took it back to the dealer to have the system vacuum sealed and refilled. Total cost, including initial fill with UV dye and subsequent fill after I replaced the parts, $290. Of course you're problem could be something completely different. However, once you do identify the problem, I would seriously consider doing the work yourself.
Old 06-13-2011, 11:55 AM   #14 (permalink)
2002,5SFE
Old 06-13-2011, 12:01 PM   #15 (permalink)
2002,5SFE
part of wiring diagram:
