Yes they do get plugged, and yes they should be replaced periodically (I do it every 30k miles). Even though it may not be 100% clogged and your car may be running ok, making your fuel pump work harder to push through a restrictive filter seems like it would make the pump fail prematurely. While the fuel filter is a little bit of a pain to replace, it is waaaay easier than replacing the fuel pump.
edit - I usually compare how easy it is to blow through the new one as compared to the old one (after all the gas has drained). That will make you a believer in changing it.
Tracy Faulkner
