Power window control works in one direction but not the other. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-09-2011, 12:42 AM   #1 (permalink)
View hgrimberg01's Photo Gallery
4th Generation Power window control works in one direction but not the other.
I recently installed new speakers in my 97 Camry LE. Now for some reason, I can not lower the front passenger window from the driver console. I can raise it but if I try to lower it it blows the main power window fuse. All other power windows work from the driver console and their individual switches. The problematic window works fine from its switch.
Also, I can no longer unlock my car from the driver side. I can lock it, but not unlock it. Unlocking/Locking works fine from the key fob thus the problem is not the lock motors.
I already replaced the fuse. Could it be just a bad switch block?
Any suggestions?
Regards, HG
hgrimberg01 is offline   Reply With Quote
Old 03-25-2012, 09:41 PM   #2 (permalink)
View scotts94's Photo Gallery
It doesnt seem like many know much about wiring here to help.. but i did find out that there is module behind the change holder to the left of the steering wheel that contorls the locks, hope that helps.
scotts94 is offline   Reply With Quote
Old 03-25-2012, 09:59 PM   #3 (permalink)
View aliirmak's Photo Gallery
bad grounding regarding the speakers may affect other electronics?
I wonder how the speaker/cables are interfering with the window driving motor.
aliirmak is offline   Reply With Quote
Old 03-25-2012, 11:22 PM   #4 (permalink)
Diablo
View GaviN's Photo Gallery
That happened to my drivers door window once. Thank god my neighbor is an electrician. He spliced some wires and taped them together towards the front bottom part of the door jam and walla it worked!! 4 yrs and still working!
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
Old 03-25-2012, 11:47 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Remove the door panel and use a voltmeter to check for voltages at the connector to the motor. When you switch directions the voltages should reverse. If not look upstream at the wiring and the switch.
