Spark plug wire pops out 3/4 or wot?!?!?!?!?! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2011, 02:25 PM   #1 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
View JCamry94's Photo Gallery
3rd Generation Spark plug wire pops out 3/4 or wot?!?!?!?!?!
Old school (kinda :P) member here...
Here's my issue... anytime I put the pedal down more than 3/4 of the way to the floor, my #2 spark plug wire just pops out like nothing!
In my very little amount of research, I've heard oil leaks and bad wires cause this to happen! The VCG is brand new (but I still have a leak coming from somewhere behind the head), and I'm gonna change out the wires next paycheck.
Any additional thoughts/experiences? Thanks! 8-)
ACCIDENT...
Help me bring 'er back to life!!!
BUY MY STUFF: http://www.toyotanation.com/forum/66...e-all-obo.html
Thanks
JCamry94 is offline   Reply With Quote
Old 06-10-2011, 03:45 PM   #2 (permalink)
Avy
Gameroom cash: $818655
View pmesfun's Photo Gallery
My friend had a similar problem on his camry, we replaced the spark plug wires under warranty from Oreilly and it never happened again. I'm guessing the car starts misfiring when this happens?
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is online now   Reply With Quote
The Following User Says Thank You to pmesfun For This Useful Post:
JCamry94 (06-11-2011)
Old 06-10-2011, 03:57 PM   #3 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
3rd Generation
Yes sir! Running on 3 cylinders on the freeway is not fun! I'm just gonna take it easy on 'er til I can buy new wires next Friday. I've had the car for 40k+ miles now (not sure how long the previous owner had them on for) and have had the same wires, so it's probably time to replace! Thanks
ACCIDENT...
Thanks
Old 06-10-2011, 05:04 PM   #4 (permalink)
Gameroom cash: $811887
iTrader Score: 10 reviews
Sounds like wires to me! Just replacement should fix the issue.
Chris Crash is online now   Reply With Quote
The Following User Says Thank You to Chris Crash For This Useful Post:
Old 06-10-2011, 07:54 PM   #5 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
Is there burn mark on the end of the plug wire? Did you replace the spark plug tube seals? And recheck the torque? How's the metal gasket on the spark plug and the seat on the cylinder head? And when you reseal the valve cover used RTV at the specified points? Just listing the items.
The Following User Says Thank You to JohnGD For This Useful Post:
Old 06-10-2011, 08:32 PM   #6 (permalink)
抵抗は無駄です
fenixus's Avatar
Gameroom cash: $1139930
View fenixus's Photo Gallery
if they are Bosch wires then go ahead and toss them into garbage and get NGK from advance auto (with coupons) or amazon.
The Following User Says Thank You to fenixus For This Useful Post:
Old 06-11-2011, 02:29 PM   #7 (permalink)
1994 5S-FYOU!
JCamry94's Avatar
Gonna replace 'em on Friday! NGK seems like the best option, thanks guys!
ACCIDENT...
Thanks
Old 06-11-2011, 03:46 PM   #8 (permalink)
抵抗は無駄です
fenixus's Avatar
if they are really Bosch wires, then actually replace them with NGK and then bring Bosch wires to store that sold them to you (if you have a receipt), replace them with new ones under warranty, then go to another store of same chain and return them for a refund if it's not too late yet
that's what I did with Bosch wires (gave up after replacing them for the second time), they kept popping off because of lousy tube boot to coil connection (was so easy to break it apart...).
