AIRBAG light is on.? WTH do i do.? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-10-2011, 02:41 PM   #1 (permalink)
View astatcamry956's Photo Gallery
3rd Generation AIRBAG light is on.? WTH do i do.?
Well i have had my Airbag light on for a while, i dont know what it means er anything can ya help.? how is this fixed er what.?
And also where can i get my check engine light checked,? cause autozone and Oriely says they can only check 96 and up.
astatcamry956 is offline   Reply With Quote
Old 06-10-2011, 03:20 PM   #2 (permalink)
Gameroom cash: $119055
View thaharlequin's Photo Gallery
Short the T1 and E1 terminals of the diagnostic port (near the passenger side firewall, you can use a paper clip or the twine core of a twistie tie) and count the flashes for your CEL. Each code is a pair, so you'll get like 5-2, or something, then look that up in the FSM. There's a link to it in one of the stickied threads in this forum.
thaharlequin is offline   Reply With Quote
Old 06-10-2011, 03:20 PM   #3 (permalink)
View Jrobb74's Photo Gallery
Can't help much. Disconnect the battery ground for about 30 min. The check engine light will go off and with luck it might stay off. That takes all codes out of computer. Don't try to get a smog inspection because they can tell with no codes at all. It will probably come back on within 50 miles but sometimes that works. As for smog inspections there is A sweet spot where just before the lt comes back on the computer is resetting and the code isn't thrown yet. I was told this by a mechanic at AToyota dealer. He said he had done that A couple of times.
Jrobb74 is offline   Reply With Quote
Old 06-10-2011, 03:58 PM   #4 (permalink)
Depending on what the problem is it'll take about 50-100 miles before it trips a CEL. The best time to take it is after it figures out how to idle right and before it trips a CEL. I've passed a few CA smog checks this way with two out of three O2 sensors down.
Old 06-10-2011, 07:55 PM   #5 (permalink)
Domesticon Prime
Gameroom cash: $206500
View Silent Runner's Photo Gallery
3rd Generation
Owners manual says that if you disconnect the battery for more than a short time, the air bag light will come on, and you have to go to a dealer to have it reset. I'm sure there's an easier/cheap way to go, but I haven't researched it yet myself.
(Probably nothing wrong with airbag thing, just has to be reset)
You can also clear codes by just pulling the EFI fuse out of the underhood fuse panel. It may come back on after a bit, or it may not. (as in my case)
Domesticon Prime
93' LE V-6, 303K Km., fully optioned including Leather Interior. ES300 rear discs, twin piston front calipers, Depo Chromes with HID projectors, 17" OZ' summer's, 96 corner lights, MAF, timing, exhaust and intake mods, 2001 Toyota/JBL sound, + more and always more coming.
Silent Runner is offline   Reply With Quote
Old 06-11-2011, 06:38 PM   #6 (permalink)
ill try that, light go annoying to be seeing it all the time.!
Old 06-14-2011, 11:32 AM   #7 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
There's no need for words like that on the forum, even if it's not spelled out all the way I know the light is annoying, we all hate seeing bright lights blinding us on the dash, but relax! There is a fix, it's not permanent.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
The Following User Says Thank You to arabianobsession For This Useful Post:
BLUEMEANIE (06-14-2011)
