I believe I have tracked down the culprit with my canister problem. Being I don't have access to another unit to compare it to I was wondering if someone could verify that this system functions in the manner I would expect it to.
On this model of canister it has two Vacuum operated valves. Valve #1 has one diaphragm. Valve #2 has two diaphragms, a bottom side diaphragm and a top side diaphragm.
Bottom side test fine with no leaks.
Top side diaphragm test will not hold a vacuum. I can hear the valve moving and make contact inside. (but I wouldn't think it could maintain a good seal if that were a normal function)
Normally I'd say "It's bad", but sense it's going to cost $361.00 (plus Tax) and I'm not subject to just throw money at it hoping for the best.
It would be Greatly Appreciated if someone could verify.
Thanks
Tom H
