Well guys, the time has come for me to think about something more practical, truthfully maybe a new project. I'd like to sell it as a whole, rather than part it out. I am posting this to gauge interest, not call dibs on this and that (not just yet). If you want something, take it to PM, I'll take it into consideration
I did come up with some new editions this year, tough I have been unable to really clean the bejesus out of it for a proper photoshoot, but I'll get one up soon enough
as for mods, well this'll give you an idea of what we have here
3.0L V6 (3vzfe)
NGK plugs and wires.
RS Akimoto Short ram intake with foam filter
Billet aluminum radiator catch can
Triple gauge pod (all red digital), volts, air/fuel, and oil pressure (I havent hooked up the sending unit)
Red silicone hoses (makes it look pretty)
Venom Nitrous computer controlled nitrous system, mated to twin 15lbs. tanks with liquid filled marshal gauges.
36 way adjustable K sport coilover suspension.
Whiteline 21MM rear sway bar, with MOOG endlinks
custom built BBK, utilizing Toyota Supra twin turbo rotors (NOTE that you can't run less than a 17" wheel with this, reality most 18"s barely work for this.
EBC green stuff pads with Cross drilled and slotted Brembo rotors (zinc plated so they dont rust and look god aweful.
SPEC stage 3 clutch
11lb Fidanza ultra light flywheel
Optima Red top battery, with Stinger battery terminals (no corrosion)
TRD short shifter (this is a 1 off as they only made these for newer camrys, so this was a retrofit)
Bronze shifter base bushings.
Apexi SAFC
PROTOTYPE Doluck floor bar
Sparco Torino seats (not fake, REAL ones, new alone these are upwards of $1200), with Sparco seat bases (another $300 there).
Sparco Flash 5 steering wheel, with a NRG short hub base and a NRG quick disconnect (so you can take the wheel with you if you want).
Sparco foot pedals.
18 TSW Thuxton rims wrapped in Falken rubber
Sparco 3 point Y belts, with harness bar, so they fit snug and functional.
Onto the ICE.
JVC NT1 GPS/DVD navigation unit (Bluetooth, MP3, USB drive), with 6.1 screen, rigged to play DVDs whenever you want
3 JVC 6.5 screens (1 in the glovebox, 1 on either side of the nitrous tanks.
17 LCD in the upper half of the trunk, this was a real chore to get done, but molded well.
Xbox 360 (set underneath the nitrous tanks, it has the hard drive and the wifi unit also)
Lots of neons in the car (in the vents, in the trunk, under the seats, in the glovebox (there is an LED undercar kit, but I havent used it in some time)
Onto the audio
MTX 5 Ό components in the kick pods up front (Q logic pods) (crossovers are in the glovebox behind the SAFC and the screen)
MTX 6 ½ components in the front doors
MTX 1 tweeters in the rear C pillars.
MTX 5 Ό components in the trunk above the subs (for rear soundstage at events)
Kicker 6x9 mid bass drivers in the rear deck (8 ohm models, bridged to a 4 ohm load)
MTX 12 subs in the trunk (bridged to a 2 ohm mono load)
MTX 4 channel amp (to run the rear fill of the car, I think it is 50 a channel)
MTX 5 channel amp (to run the front and the sub, the sub is a D channel amp, and more than enough to move the 12s)
Other goodies
JDM 1 Piece Scepter Headlights, with HIDs (8K), I never got around to setting up the H# foglights in the lenses though.
JDM Scepter Taillights and Center Panel.
JDM Scepter power folding mirrors (with relays and controls , I never got to hook them up though)
NOTE that these alone cost me almost $900 and are very sought after items that I doubt I could ever find again)
Erebuni style body kit
VIS carbon fiber Hood, one of the original 50 produced
some pics to show her in her glory can be found in show and share
I give to you the awaited, KNAILGUN version 4.0 56k no way
