1996 Camry Front Shock Mount Replace, Need alignment? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-15-2011, 10:46 AM   #1 (permalink)
View plurpimpin's Photo Gallery
1996 Camry Front Shock Spring Nut Size?
Ok so this weekend I'm going to replace the front shock mounts on my 1996 camry. I installed new shocks in January and the mounts were fine at the time so I kept the old ones (bonehead move on my part). The mounts started rattling about a month ago.
My question is do I need to get the alignment re-done after replacing the mounts since I'm keeping the same shock?
I searched abunch but couldn't find an answer.
plurpimpin is offline   Reply With Quote
Old 06-15-2011, 11:33 AM   #2 (permalink)
71Corolla's Avatar
Gameroom cash: $548750
View 71Corolla's Photo Gallery
There is no adjustment possible on the shock itself, so in theory your alignment will not change. Last time I had my car aligned I asked the tech about this, he said that there is slight movement in the strut bolts, but it is not enough to put the camber out of spec. In some cars, the strut has oblong holes to allow for adjustment, not on these cars. So you should be fine.
2000 Lexus ES300 Millenium Edition 1MZ-FE 64,000 Km
1993 Camry V6 LE 3VZ-FE 164,000 Km SOLD but still in the family
1990 Camry LE 2VZ-FE 202,000 Km
1987 Camry LE 3S-FE 435,000 Km
1971 Corolla 2-door Coupe 2T-C 260,000 miles
71Corolla is online now   Reply With Quote
Old 06-15-2011, 01:08 PM   #3 (permalink)
Ok cool, that's what I was thinking. One other random question, What size is the nut on the shock shaft that holds the spring and mount on? It's larger than anything I have so I'm gonna have to go out and buy one
