I would have a Locksmith go to the car and Re-key it If i were you. He will make you a Blank key.
By the way, i'm pretty sure that the 92-96 camry didnt have a Chipped key. It only had a FOB (Keyless entry remote).
If you dont have the remote for the keyless entry, there really isnt much you can do besides bypass the System, but you will still need a Cut Key to start the car.
There should be some large wires underneath the dashboard. They will be spliced and run to the Alarm ECU, you need to pull these splices apart and connect the colors up.. (White/black to white/black, etc..).
Once you get the system bypassed, put the key you had cut by the locksmith in the ignition, and your good to go.
